Old 08-09-2010, 05:34 AM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Replacing Battery Box
Well last weekend we were out camping and subjected to some severe thunderstorms and heavy rain. Unfortunately I left the front battery door open to cool down the battery that we cooked the night before. Woke up with wet feet (sleeping on the floor as we have the trailer in deconstruction phase). After pulling the battery noticed the battery box is cracked from front to back. This could explain some past water stain around the battery box. So now it's time to address this. I've searched the forums and found post that several have gotten the white battery box with vent tube and eliminated the front door access. For those that have done this, where did you vent the battery. I don't want to be cutting holes in the trailer. Has anyone taken out the original box and replaced it. Looks like some rivets holding it in but access could be a challenge. And how well does it seal. The original box is angled down inside the coach...how did these things drain, if at all. Any thoughts? Thanks!
TAC PA-5
WBCCI 4871
Name:	Front End 3 jpeg.jpg
Roadrunner is offline   Reply With Quote
Old 08-09-2010, 05:58 AM   #2
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I added a second battery box to match the original such as what you have. If it were me I would try to keep the original box as is. I would remove it and replace the plastic box one with a new or use an epoxy glue and seal the leak (crack) in it. Originality is the ticket in my opinion. Since you have the cabin open I would consider a second battery box to match the one you have, gives you much more electric storage for boondocking.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 08-09-2010, 06:19 AM   #3
1986 25' Sovereign
Plant City , Florida
I second airdreamers... this is a great time to fix the existing issue and add another battery. I believe that the battery will be the most expensive part of the project.
ck21084 is offline   Reply With Quote
Battery Box Lumatic Batteries, Univolts, Converters & Inverters 7 12-27-2008 11:13 AM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
Battery Box aztlanco Batteries, Univolts, Converters & Inverters 5 08-17-2004 05:56 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
