Old 05-07-2019, 06:41 PM   #1
2015 25' FB International
2019 27' Globetrotter
Santa Barbara , California
Replacing 12V Deep Cycle with AGM or Lithium
Greetings,
I just tried to post a lengthy thread about our considerable woes with battery charging and retention in our last two NEW Airstreams, but the website timed out before I could finish. That is probably to your benefit. So, now, Ill cut to the chase.
2019 AS Globetrotter 27FB
Interstate 12V Marine/RV Deep Cycle Batteries
100 watt flexible photovoltaic solar panel
Go Power 40 amp MPPT Solar Charge Controller w/ Remote Display
After only 2 overnight outings, one of which was in full hook-ups, our batteries are dead and irreparable.
QUESTION: Can I replace the 12V lead-acid batteries with either AGM or Lithium batteries, while still utilizing the existing electrical wiring, charge controller, inverter, converter/charger, and solar panel?
We need to significantly improve/upgrade our existing battery power, as we really enjoy boon-docking (Yes. We have two Honda 2000 watt generators).
Any helpful input would be appreciated.
Thank you. M & M
M and M is offline   Reply With Quote
Old 05-07-2019, 10:20 PM   #2
2007 27' International CCD FB
San Diego , California
The simple answer is no at least in regards to the two components that's charge profile need to match the battery technology: solar charge controller and converter/charger.
There is a chance that these components depending on the model, can be configured to support one or both of the battery chemistries you're proposing.
That said, the failure of your current batts is not due to the technology they use. Many a new trailer has been delivered with batts that have sat in a depleted state for long periods. A sure way to kill them dead.
Personally, I'd just drop two 6V batteries into the box and give it a whirl. No need to worry about changing anything else.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 05-07-2019, 10:36 PM   #3
Vintage Only
1966 26' Overlander
1981 31' Excella Limited
1964 22' Safari
Ramona , California
With all due respect I don't think the response is correct. If you have 2 12 volt batteries that are wired in parallel you cannot just drop in 2 6v batteries. You would need to connect the 2 6v in series. The comment about the likely cause of the dead batteries is valid and you should try to get interstate to replace. Finally if you use lithiums with a built in BMS such as Battleborne you should be able to drop in 2 12v lithiums and be fine. There are ways to get an overall better optimization with other changes but what you have should be ok. There are tons of threads on the subject and many options you can consider.
1966 Overlander, 1981 Excella II, 1964 Safari (for sale)
kenfconnor is offline   Reply With Quote
Old 05-07-2019, 10:42 PM   #4
Fair point. I don't generally consider this to be a wiring change of any significance. I will offer amends:
Old 05-07-2019, 11:16 PM   #5
Vintage Only
1966 26' Overlander
1964 22' Safari
Ramona , California
Attachment 340092
Thanks pteck. I agree but not knowing the background on the OP feared something mught smoke :-) The images you posted should be very helpful.
Old 05-08-2019, 09:18 AM   #6
Sherwood Park , Alberta
Solar Pre-Wire is 8 AWG in 2019 Globetrotter 27FB
I've just gone through an upgrade to my Factory solar in my 2019 Globetrotter. In case you wish to go down this path it's worth noting that the factory pre-wire for solar is 8 gauge, not 10 gauge as commonly believed.
Be sure to verify by checking the green and yellow wires located under the front bed.
Just thought this might be useful info when determining options.
ID:	340136   Click image for larger version
Omnial is offline   Reply With Quote
Old 05-08-2019, 09:34 AM   #7
1996 25' Excella
Tillsonburg , Ontario
Just a note on getting timed out
That has happened to me a few times. Just do your message in word or a text program and copy and paste it into the AS forum message.
JCW
JCWDCW is offline   Reply With Quote
Old 05-08-2019, 09:49 AM   #8
Skycar's Avatar
2014 19' Flying Cloud
Newmarket , Ontario
I just switched to three Battleborn 100 amp hour lithium’s on my 2014 19 feet flying cloud. The batteries should not go outside in the front box. They do not perform well in the cold. They will shut themselves down before any damage can be done and therefore won’t be able to be used in freezing temperatures. Mine are now under my bed, which is in the back of the trailer next to the back of the water heater. I also have a 2000 W Go power inverter under my dinette in the front of my trailer along with a TriStar PWM solar controller for my 300 w solar panels on my roof. I know that you’re going to say that I need a MPPT unit, but with the changing of the dip switches it is adequate for now. What I’ve come to find out is that the distance between everything will not allow the inverter to work properly. Go says that I need 2 0 wire, rather than the 2 gauge I currently have. So now, I’m going to have another company move the inverter to the back of the trailer as the least expensive method. So far I really like the batteries and have not gone under 82%. I would also install a Victron battery monitoring system, because just looking at the volts will not give you an accurate reading of how much you have left. I’ve installed all of this because I fulltime and like to boondock as much as possible. This is just my experience. I’m not an expert, but I’ve learned quite a bit the hard way!
Skycar is offline   Reply With Quote
Old 05-08-2019, 10:06 AM   #9
chicagoair's Avatar
2019 19' Flying Cloud
Chicago , Illinois
Originally Posted by Skycar View Post
The batteries should not go outside in the front box. They do not perform well in the cold. They will shut themselves down before any damage can be done and therefore wont be able to be used in freezing temperatures.
Some more detail is needed here, for most practical purposes they are fine in the cold.
The batteries will discharge down to -4 degrees F. They will not accept a charge below 24 degrees F.
We keep our two Battleborns in our outside (slightly modified for size) battery box and the temperatures have never been an issue. Even if it drops below 24 at night, were not getting solar then anyways to charge. If daytime temps are below 24 for multiple days, were moving.
The batteries are the best upgrade weve made on our trailer. With 2 100Ah Battleborn batteries we can easily get a week of use out of them without hooking up our external panel. We can go indefinitely with the panel.
chicagoair is offline   Reply With Quote
Old 05-08-2019, 11:19 AM   #10
Bev Hills , California
batteries
I've had considerable experience with this. First your problem is either a defective battery or a short circuit/con't load that is draining your batteries. I would turn off everything, disconnect a fully charged battery and see if it holds its charge. If it does, then the battery is not your problem
Put it back in place and turn on the loads one at a time every 24-48 hrs until you find the culprit .
Regarding replacing, 6V golf cart batteries in series are the best. I have used them in the boating for the past 20 years.
Whether you go to that, lithium, AGM etc should not matter as almost all charge controllers and chargers in the past fifteen years allow you to configure them for the battery type. The only issue is the size of the battery compartment.
KLK
Keithkleinmd is offline   Reply With Quote
Old 05-08-2019, 12:39 PM   #11
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
Reseda , California
You can replace the two 12v Deep Cycle with two 12v AGMs, I just did that and nothing else changed.
However, anything beyond that, then you will have to consider other factors.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 05-08-2019, 01:20 PM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I think the batteries are bad. If they went down while under full hookups something else is bad also. I think trouble shooting is in order. Probably by starting with fresh batteries. Then check the converter to see if the output is correct. Even if I was going to AGM's I think I would put a set of flooded in until I got the real issue fixed. Sounds a lot like the converter was turned off or defective. Did you run an inverter the night without shore power? Or the furnace?
Old 05-08-2019, 02:32 PM   #13
waninae39's Avatar
2017 22' Sport
NCR , Ontario
if you have 2 or more 12V battery and need to put them in parallel be careful
ensure that you use a very heavy gauge like 0 or a buss bar.
the issue deals with where the +ve and -ve cables go. if the same guage cables are used between batteries and the two load-side are on one battery, the other battery(s)could get a lower charge or not be used as much load
since you want to use both equally, you need to ensure that the supply cables use all batteries equally
this has been posted elsewhere many times
waninae39 is offline   Reply With Quote
Old 05-08-2019, 10:41 PM   #14
Skycar's Avatar
Newmarket , Ontario
As far as temperatures go, Im Canadian. So it can get well below 0 F for extended periods of time. I would not want my batteries exposed to cold like that. Therefore, I will keep them where they can be protected and kept at a reasonable temperature. As well, with three of them, there is no way they could fit in the front box.
12v
Lithium or Deep Cycle Batteries? ScottandMoni Batteries, Univolts, Converters & Inverters 93 05-10-2019 09:33 AM
AGM to Deep Cycle Batteries Bradley G Batteries, Univolts, Converters & Inverters 18 05-04-2019 09:09 AM
Lithium Batteries or Deep Cycle? CamanoIsland Generators & Solar Power 29 06-02-2018 05:46 AM
Battery Swap from 12v Deep Cycle to 2x L16 for more amp hours Vycan Classic Motorhomes 24 05-07-2016 11:05 PM
deep cycle battery replacement 26Argosy.ca Electrical - Systems, Generators, Batteries & Solar 6 01-02-2003 05:19 AM
