Old 05-13-2007, 09:07 PM   #15
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
I installed the Parallax 4455 with temp control which I bought from Randy about a month ago. I was leaning toward the intelicharger at first, but it seems that the temp control will do a better job of adjusting the power to the batteries. I upgraded to 3 29 series batteries using the advise I found here, and the charger has done a good job so far.
Charlie
Pacerized is offline   Reply With Quote
Old 05-14-2007, 09:17 AM   #16
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Originally Posted by 68 Overlander
There is a chance your converter will fail in the first 2 years you own it. That chance is less than one half of one percent. They sometimes just fail....
Randy,
You are certainly correct, but ... depending on how you use your rig, having a converter fail can be very serious. No converter, your battery discharges and you have no 12V power and no way to charge batteries. No lights, no furnace, no water pressure. Ruins your day if you are on a weekend camping trip. A bit more serious if you are a long ways from home or boondocking in a remote location and relying on a generator to recharge your batteries.
I speak from experience. 15 degree temps and no furnace is not fun.
I'd suggest always carrying a spare converter or at least a battery charger
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
Univolt Replacement rjones1138 Electrical - Systems, Generators, Batteries & Solar 19 10-21-2002 03:31 PM
Bad Univolt? pebblepoint Batteries, Univolts, Converters & Inverters 1 07-14-2002 10:08 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
