Old 03-10-2014, 09:50 PM   #1
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
replace Univolt or just needs charge
OK, my Tradwind has the original Univolt. It seems to be doing ok, no noise, but. Today I worked on her, and was not hooked up to electric (none on since fall (Nov)) I put a CD in the player and it worked a while, then as soon as I turned on a light, it stopped/started/ stopped. Replacing it is on the list, but do you think it's because it has not been charged in 4 months? The battery is just over 1 year old. I will test the battery and charge it if needs it. The CD player did cut out some last year as well when many lights are on. I guess I know the answer just looking for confirmation. John
moparjohn is offline   Reply With Quote
Old 03-10-2014, 09:55 PM   #2
SteveH's Avatar
Common Sense , Texas
I would bet first your battery is discharged, but an original univolt that old should not be trusted.
I would check the voltage, then plug in to shore power, and check the voltage again. That will be quick checks of the battery and the univolt.
Regards,
Steve
Univolt question Stonew98 Batteries, Univolts, Converters & Inverters 11 12-19-2011 09:15 PM
Weird Univolt noise (no not the hum) and power flicker ovrteakettle Batteries, Univolts, Converters & Inverters 12 12-08-2011 12:31 AM
Battery Tender and Univolt? AldeanFan Batteries, Univolts, Converters & Inverters 8 08-31-2011 12:16 PM
Univolt on a 1976 Caravanner wba1 Batteries, Univolts, Converters & Inverters 12 07-27-2011 08:13 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 07:20 AM
