Old 11-28-2010, 06:36 AM   #1
1979 28' Airstream Excella 28
boynton beach , Florida
Images: 20
replace and upgrade converter fuse block
looking on how to upgrade this fuse panel, the neg 50 amp ground blew and also not sure if this could be a problem with the wiring somewhere in the trailor but thought upgrading this might help to determine, Any suggestions, idea's? Thanks
nikiarntz113 is offline   Reply With Quote
Old 11-28-2010, 07:55 AM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I bought this quality fuse panel for both of my Airstreams:
12V RV Fuse Box
Do you have power going to your old fuse block?
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 11-28-2010, 08:02 AM   #3
Images: 20
Thanks but there are 6 20 amps and 3 50 amps, Have not been able to find something compatible, Would really like to upgrade to the newer fuses..
Old 11-28-2010, 09:24 AM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
This fuse panel will still work for what you want. You'll still have six circuits to spare using this fuse panel. The three 50amp protected circuits on your panel are for your main 12v power feeds and your one ground feed. Just use 50amp breakers to protect these. That's what I did for my '72 and yours is wired pretty much the same.
The 3 connectors at the top of the panel sold by VTS are for your 12v feeds; the negative bus bar on the side is where you connect your battery ground. The 12 circuits are for your individual circuits going to your trailer.
1958 Overlander
4CU 1st VP
Fuse Block or Harness Byrne Argosy Motorhomes 9 07-01-2010 09:24 AM
new fuse block bilby05 Batteries, Univolts, Converters & Inverters 8 01-16-2008 05:47 PM
Fuse Block philippes Classic Motorhomes 6 09-26-2007 08:40 PM
Fuse block driving me nuts! bkahler Mechanics Corner - Engines, Transmission & More... 11 07-08-2007 08:52 PM
Fuse Block replacement - help Craig Electrical - Systems, Generators, Batteries & Solar 6 10-13-2004 03:01 PM
