Old 10-12-2015, 10:12 AM   #1
2008 19' Safari
Toronto , Ontario
Removing batteries for winter
If I keep my 3-stage inverter plugged in to shore power for the winter (or perhaps run it for 24 hours once a week) is it really necessary to remove batteries during freezing temps (no lower that 0-5 degrees F). I understand that a fully charged AGM battery won't freeze under reasonably low temps but I don't know what that threshold temp is.
Thanks for any advice.
oscarb57 is offline   Reply With Quote
Old 10-12-2015, 10:19 AM   #2
2008 19' Safari
Toronto , Ontario
I meant "converter", of course
Old 10-12-2015, 10:28 AM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
As long as you keep them charged you should be fine. Battery disconnect switch should be in the on position otherwise you batteries may not charge, not sure what year AS you have. I have left mine outside for years with no issue in Western PA
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 10-12-2015, 10:32 AM   #4
2008 19' Safari
Toronto , Ontario
Thanks, paiceman. It's a new to me 2008 19' Safari SE
Old 10-12-2015, 11:39 AM   #5
1977 31' Sovereign
Lynnwood , Washington
Warm winter storage prolongs battery life significantly. Keep batteries fully charged. 60-70 degree range is ideal.
Tom
TomKirk is offline   Reply With Quote
Old 10-12-2015, 12:30 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
As long as you know that you have a true 3 stage converter. My converter in my 2003 Classic is not 3 stage and will ruin a battery if I leave it plugged in when the trailer is not in use. I pull the batteries In the winter and connect them to a trickle charger.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-12-2015, 12:47 PM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink
I'm with Jack...BSTS.
Lift 'em out...
...and down in the basement.
Our IOTA IQ4 does not charge if batts are not installed, so plugging in if needed is not a problem.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-12-2015, 01:04 PM   #8
2008 19' Safari
Toronto , Ontario
Thanks, jcanavera. Yes, I do have a 3 stage converter mod. The PO was engaged enough to add this mod along with a few others. Such is the advantage of purchasing a previously loved AS.
Old 10-12-2015, 07:09 PM   #9
2018 19' Flying Cloud
Eugene , Oregon
Is a float charger necessary?
I have a 2015 Bambi Sport and am looking ahead to its first winter. My question regards the batteries. I was thinking I might need a float charging system to keep from overcharging my batteries, but then a salesman told me that when I'm plugged into shore power the Airstream has a built-in float charger that keeps me from overcharging. Is this correct?
tjwoods1 is offline   Reply With Quote
Old 10-12-2015, 07:34 PM   #10
2008 19' Safari
Toronto , Ontario
TJWoods1
It's important to identify which type of converter you have installed in your Bambi. You want a three stage rather than a single stage converter. I understand from other Forum members that single stage units are typically Parallax or TrippLite and 3-stage units are typically Progressive Dynamic or Magnum The 3 stage is essential as it reduces voltage to your battery as the battery reaches full charge, and produces only a trickle charge after that. Single stage converters will overcharge your batteries and ruin them if left attached past full charge. The trickle charge can remain attached.
You should confirm directly which type you have. In my 2008 19' Safari the converter is attached (below) the fuse panel. Just open up the front panel and check the manufacturer. I found that I originally had a Parallax unit (as I understand the factory was providing them in 2008 (and maybe still) but there was a sticker attached to mine indicting that it had been upgraded by the previous owner to one of the above mentioned 3-stage units.
Good luck. There's lots on the Forums about this topic.
Harold
Old 10-12-2015, 08:12 PM   #11
1974 Argosy 20
Kooskia , Idaho
You might like to read my all winter test of storing a battery in a freezer at 0 to 5 F.
http://www.airforums.com/forums/f449...ml#post1602338
Old 10-12-2015, 08:45 PM   #12
Manheim , Pennsylvania
First year winterizing question. Do I have to remove my AGM batteries over the winter? They are connected to the two 53 watt solar panels and charge controller that came from Airstream.
Jukeboxfun is offline   Reply With Quote
Old 10-12-2015, 10:01 PM   #13
richw46's Avatar
Lexington , Kentucky
I have a single solar panel and it kept my batteries topped off all last winter. Well, except for the 4 weeks I was down in Florida
I have my AS in a storage lot and the solar does a good job of keeping them charged. The reading has been 12.7 whenever I go check on it.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-13-2015, 09:01 AM   #14
2008 19' Safari
Toronto , Ontario
idroba
Thanks for your (re-)post. Very interesting. Your evidence-based findings seem to provide the definitive opinion on this question. This was most helpful.
Batteries Left in Camper in winter PARKS1963 Batteries, Univolts, Converters & Inverters 6 12-24-2008 05:40 PM
winter batteries kepko Batteries, Univolts, Converters & Inverters 18 11-10-2008 01:41 PM
Leaving batteries connected over the winter StAlphonzo Electrical - Systems, Generators, Batteries & Solar 7 10-02-2008 02:44 PM
Tie House & Coach Batteries for Winter Storage? N2XBW Electrical - Systems, Generators, Batteries & Solar 5 11-23-2007 10:29 PM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 09:17 AM
