Old 06-20-2016, 04:03 PM   #1
1973 25' Tradewind
Redding , California
Removed UNIVOLT. wiring questions...
Pulled my Univolt, Purchased my boondocker and 12v panel but I have a few questions.
1. The 120v wiring going into the univolt was not grounded. When I wire my plug for the new converter, should I run a ground to the frame?
2. The boondocker has a 12v positive, negative and a chassis bonding lug. Do I attached a wire from the bonding lug to the frame?
3. The univolt had a white cable labelled "negative load" that appears to be a ground wire (see attached photo). do I attach the white wire the 12v panel ground terminal?
4. the black wire coming from the battery has a fuse that attached to the floor. see pic. Should I upgrade this? I ran an ohm test and the fuse is good.
5. There is a white wire that appears to be attached to frame in the closet where all this is taking place. should I run a wire from this lug to the ground of the 12v distribution panel?
Thanks! Sorry if this is confusing. I'm confused... LOL.
ID:	264850   Click image for larger version
ID:	264852   Click image for larger version
Leadvox is offline   Reply With Quote
Old 06-20-2016, 07:50 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi leadvox, welcome to Air Forums and the vintage Airstream hobby. I have a 66 Trade Wind and think the 25 foot size is just about perfect. I also installed a boondocker in my Trade Wind. I will try to answer your questions.
Yep, you want to ground the 120v circuit. I happened to run a dedicated circuit to the boondocker from the circuit breaker box because I could. The entire 120 volt wiring inside the trailer is grounded to the frame. I believe the 120v cord coming out of the boondocker is a three prong plug.
Yep. But you will attached it to your 12v ground. My trailer has a 12v ground "bolt" and a 120v ground "bolt" to the frame rails. I wrestled both the rusty bolts off, cleaned the rusty frame to insure a good contact to the frame. Now, my fuse panel has a dedicated copper wire to the 12v ground. So you can ground the boondocker to the fuse box ground bus if you like. The 12v ground from the boondocker to the trailer frame ought to be low resistance, like less than 5 ohms.
Careful here. My trailer has black 12v positive, and white 12v negative. My trailer has three separate 12v circuits radiating from the fuse panel. Your fuse panel will have a white wire "bus" for all the 12v negatives. And your fuse panel will have a bare copper wire running to the 12v frame "bolt'. It is true you can place your multi-meter on the 12v positive battery terminal and the trailer skin and read 12 volts. But the fuse panel is grounded separately.
If the fuse is good, then okay to leave it alone. It helps protect the 12v circuits from overload, like a seized furnace fan motor.
Yep. I used bare copper wire, 10 gauge.
I believe others more expert than I will edit this response and steer us to the best boondocker installation. But at least I am exposing my ignorance. But hey, at least my boondocker is working as advertised and my trailer didn't catch on fire.
David
Name:	1405 Electrical New Converter.jpg
ID:	264861   Click image for larger version
Name:	1405 Electrical  New Fuse Panel.jpg
dbj216 is online now   Reply With Quote
Old 06-20-2016, 10:05 PM   #3
1973 25' Tradewind
This. is. awesome. Got it all hooked up and it worked! Thank you so much David! This forum has been so helpful. I was just reading in another forum area about the shunt in the univolt for the ammeter. I am heading out to the trash to pull it right now. Total time to wire everything was less than two hours. Of course that time does not include the many hours poking around on these forums... Thanks again.
1972 Overlander Univolt Wiring Diagram SailorGal Electrical - Systems, Generators, Batteries & Solar 2 06-20-2016 04:10 PM
To Univolt or NOT Univolt? aircooled4 Batteries, Univolts, Converters & Inverters 11 05-13-2012 07:20 PM
Univolt replacement wiring? AYRSTRM2 Electrical - Systems, Generators, Batteries & Solar 25 05-20-2006 11:01 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
