Old 04-29-2016, 12:02 PM   #1
1975 29' Ambassador
Portsmouth , New Hampshire
Unhappy Remove battery and just use shore power
I've recently purchased a 29' '75 Airstream Ambassador with rear bath. I plan to park it on my property permanently as a guest house. On it's trip home from the seller the battery compartment came open and the battery disappeared.
I've been working on it for a week and all of a sudden while messing with the rusted out step light all the front interior lights went out. So I bought some new 20 amp fuses and replaced it on circuit #4. it worked for a short while and then the fuse burned out again. Replaced it and then the #1 circuit burned out. Then the #2 circuit burned out. Now only the #3 circuit is working.
I assumed there was a short somewhere and then I read on the forums that it's not a good idea to keep the inverter running without a battery in place. Maybe that's the issue. Am I burning out the system by not having a battery??
I've decided that getting a battery and constantly charging it is dumb since I never plan to move the trailer from the house.
So to my question: Can I bypass the existing battery charger/inverter/univolt system and just buy a converter that turns the AC current from the house to 12v DC power and just hook up all the wires to it? Has anybody done this?
jwgayle is offline   Reply With Quote
Old 04-29-2016, 01:25 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
If you still have the old Univolt lump, you don't have an inverter. It's a converter/charger, and they weren't designed to function reliably (e.g. with consistent output) without a battery in the loop.
A more modern converter/charger should be able to function without a battery, you just need to size it to support the maximum likely 12v load you'll place on it with the lights, pump and fans.
David
Old 04-29-2016, 03:20 PM   #3
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
It would be a great idea if SOMEONE published a GLOSSARY of acronyms and shorthand; so that those of us 'unwashed peasants' who are at a disadvantage in following some of these 'threads', can do so.
MelGoddard is offline   Reply With Quote
Old 04-29-2016, 03:36 PM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
.....Do'n the google
PFC
RLC
Step aside Starbucks, this is a job for alcohol.
Old 04-30-2016, 10:37 AM   #5
1975 29' Ambassador
Thank you everyone for your help. I gave up and bought a battery but then also discovered that there was a loose fuse holder on circuit #4. I installed the battery and fixed the fuse holder and it ran without smoke and dripping fuses for about 6 hours last night without issue. Hopefully it keeps running.
I think I will eventually replace with modern converter as suggested. Would this be a good one: IOTA DLS-55/IQ4 12 VOLT 55 AMP 4 STAGE AUTOMATIC SMART BATTERY CHARGER / POWER SUPPLY
http://www.amazon.com/DLS-55-AUTOMAT.../dp/B0074JVO0A
Is there a better or more affordable model?
I guess $200 isn't bad to get rid of the fear I feel when I look at that rusted out univolt and converter.
Old 04-30-2016, 11:57 AM   #6
DKB_SATX's Avatar
1976 Argosy 28
Iota and Progressive Dynamics are the trusted name brands and PowerMax is the trustworthy bargain brand. I wouldn't buy another WFCO and wouldn't consider trying an unknown brand. I have a PowerMax from Best Converter that has been flawless for 4 yrs now.
David
Old 04-30-2016, 01:03 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you are never going to use a battery, you are going to be getting more than you need with a 4 stage converter/charger. A decent, single-stage converter will work acceptably in that situation.
Old 04-30-2016, 01:12 PM   #8
DKB_SATX's Avatar
1976 Argosy 28
This is a valid point. I'm not sure if Iota sells a single-stage converter, but ProgressiveDynamics definitely does and the PD converters you find at the best price on Amazon for a given wattage are almost always the single-stage models.
A nice thing about the Progressive Dynamics converters... if you buy the single-stage unit and later decide you'd like to have a battery in the system (for power outages, because you've decided to travel with the trailer, etc.) you can upgrade it to 3-stage with the ChargeWizard plug-in dongle.
Here's a 45-watt example on Amazon. I've no idea if you can find the 9145 cheaper somewhere, it was just an easy search for me.
David
Old 04-30-2016, 01:15 PM   #9
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I use an iota dls55 iq4. Been flawless for years. Plays well with my solar charging as well.
Old 05-01-2016, 02:05 PM   #10
I would advise to get a battery, even a somewhat worn-out one and hook it into the system. Why??
Because a battery is an 'accumulator' that acts as a 'snubber' to absorb and smooth out voltage spikes, and such.
Of course, a serviceable one would also act as a power back-up supply, but you knew that anyway.
Battery Good No DC Power with shore power off. Frank Ross Batteries, Univolts, Converters & Inverters 15 08-09-2014 03:42 PM
HELP?! On Shore Power, but lights dim, and power fades TGadaire Batteries, Univolts, Converters & Inverters 4 11-24-2012 05:18 PM
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 01:53 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 06:32 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
