Old 10-11-2016, 05:53 PM   #1
2010 31' Classic
Mobile , Alabama
Remote on/off of inverter no workie!
I have a 2010 30' Classic that has a inverter Mod.WF-600T... The remote that turns it on has stopped working... You can turn it on with the on switch on inverter itself... I removed remote switch from wall and connected it to the inverter with a new phone line to eliminate possible issues with phone line in wall and same problem, can not energize inverter with remote switch... So any body experience this issue and if so what was your fix?
Thanx
Greg
Rutrodeo is offline   Reply With Quote
Old 10-11-2016, 07:27 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Thanx
Greg
Greg,
First, the 'phone line' used for your inverter is not, in fact, a 'phone' line but a data cable. One RJ-11 plug is reversed in it's color orientation from the other so that when you place them facing each other with the detachment nib in the same orientation (with both up or both down), the colors line up.
I'm not a service tech for WFCO, as my exposure to their products has been to remove them for upgrades with Magnum or Victron components, but you might try using a 'data' cable wired directly to the inverter before looking to replace the remote control panel.
Old 10-11-2016, 07:57 PM   #3
2010 31' Classic
Mobile , Alabama
Short cable
So maybe thats why there is a short line thats added to the phone line from the remote jus before the inverter, thats where the reversal takes place?
Greg
Old 10-11-2016, 09:32 PM   #4
lewster's Avatar
Greg
Airstream typically uses a single, continuous cable from the inverter to the remote's location in the galley wall, at least on all of the units that I have worked on. WFCO typically uses a narrow, 4 conductor only plastic RJ-11 'type' plug, but it is too small to properly fit into any standard RJ-11 port which accepts either 4 or 6 conductor RJ-11 plugs. Magnum inverter/chargers require the 6-slot standard RJ-11 plug, which I install onto the existing 4 conductor cable that's present. Victrons use a Cat-5 cable.
You might have an issue with either a cable end or a union if Airstream used one to lengthen an improper length cable. If you have the standard sized RJ-11 cable, you might try reversing one of the end RJ-11 plugs to see if that will get communication between the inverter and the remote.
Magnum MMS1012 1000W Pure sine Wave Inverter w/50 Amp Charger & Remote exallen Airstream Classifieds 0 06-05-2016 04:25 PM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 02:48 PM
Inverter Switches Off After a Couple of Minutes Ljsydney Electrical - Systems, Generators, Batteries & Solar 9 03-25-2014 10:28 AM
Inverter - On or Off? big_john Batteries, Univolts, Converters & Inverters 23 11-23-2009 02:56 PM
OPD valves, Sight Gauges & Remote Senders femuse LP Gas, Piping, Tanks & Regulators 1 04-29-2003 08:41 PM
