Old 09-26-2014, 11:56 AM   #1
2015 23' FB Flying Cloud
Vancouver , British Columbia
Remaining Charge in Batteries?
Just spent our first night in 2015 Flying Cloud 23FB. Have figured out that the Sea Level II monitor shows VOLTS for the battery (11.9).
We have two 6 volt batteries and are boo docking. How can we tell how much power is left in the batteries?
We are new to this and have no sense of how much we are eating into the battery power. Being very frugal present!
FlyinNitwits is offline   Reply With Quote
Old 09-26-2014, 12:53 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Below 12 volts is basically dead. Time to recharge before it gets any lower.
MICHAEL
Old 09-26-2014, 01:15 PM   #3
New Borockton , Alabama
Images: 21
The only way to know for sure is with a monitor that measures amp hours instead of just volts. A resting deep cycle battery is at about 50% state of charge at 12.2. Michael is correct that 11.9 is nearly discharged.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 09-26-2014, 01:35 PM   #4
mefly2's Avatar
2015 25' FB Eddie Bauer
Buy (or get one free at HF with coupon) an inexpensive digital volt meter and check the individual batteries to see if one or both are fully charged or dead ...
Old 09-26-2014, 05:01 PM   #5
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Install a proper battery monitor that actually shows Amps being used. I installed the best one out there the Trimetric TM 2030, and I am amazed as to how little and how much certain electronics use.
They should be standard instead of those idiot monitors they install.
It's like driving a car without a fuel gauge if you don't have one. Unless you are always plugged in.
George
gandttimes is offline   Reply With Quote
Old 10-03-2014, 03:17 PM   #6
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Voltage Chart
12 volts is 50% capacity.
Old 10-03-2014, 03:22 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks for the chart KJRitchie. Yep, when the volt meter says below 12v, time to plug in and charge up.
David
Old 10-03-2014, 03:40 PM   #8
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Look up your battery manufacturer and type online. They should provide you battery specific information, such as this...
http://www.exide.com/Media/files/Dow...0%205_9_13.pdf
That should tell you EVERYTHING you'd ever want to know about your battery's charge, at least until it ages a little, and the capacity is reduced, then it's all out the window without a set load and data sheet for capacity testing...
-Red, who does a bit of battery testing...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 10-03-2014, 03:43 PM   #9
Panama Red's Avatar
Obrien , Florida
So, instead of slogging through all that hoohah, just plug up and charge when it hits 12 volts, like those guys said...
-Red
Old 10-03-2014, 05:57 PM   #10
Thanks everyone. Will go with the 12 level limit.
Penny
Vancouver, BC
2015 Flying Cloud 23 FB / soon to be towed by VW Touareg TDI
Old 10-04-2014, 10:33 AM   #11
Images: 21
Hang on now Penny. What batteries did Airstream provide you with? The chart is a guide and there can be a significant difference between 12.0 and 12.2 over time if you plan to do a lot if boondocking. Red could be perfectly correct but many manufactures list their open cell voltage 50% discharge different. Make sure and you might "buy" a year of extra life knowing what they recommend.
Old 10-04-2014, 12:06 PM   #12
Panama Red's Avatar
Obrien , Florida
^^^^^^^^^Good point!^^^^^^^^^
a couple remaining questions about interstate fuzzysb Sprinter and B-van Forum 12 11-01-2014 03:24 PM
How do you measure remaining propane levels? Gringo LP Gas, Piping, Tanks & Regulators 19 10-02-2012 01:59 PM
Only a Few Brakesmart Controllers Remaining! Dumpster Brakes & Brake Controllers 8 07-16-2010 11:04 AM
Remaining Naked after Stripping? Becky B. Cleaning, Stripping & Polishing 8 03-25-2008 08:35 PM
Full Charge - No Charge! Cracker Batteries, Univolts, Converters & Inverters 2 06-22-2007 02:04 PM
