Old 09-26-2010, 03:07 PM   #1
2008 23' Safari FB SE
Boulder , Colorado
Recommendations for trickle charger?
It is my first season winterizing my 08 23FB SE and I am wondering what type of trickle charger you folks recommend for removing/storig the 2 marine/RV batteries on the unit for winter.
Any particular brand or things to look for on the charger?
Thanks!
Sandy
bonginator is offline   Reply With Quote
Old 09-26-2010, 03:27 PM   #2
Hawkeyes & Harleys
HOG-I's Avatar
2006 16' International CCD
Las Cruces , New Mexico
Thumbs up Battery Charger
I use a Battery Tender Plus on my Harley and Batteryminder on the AS. Most any good charger/maintainer will work. The Batteryminder can be found at RV supply. Battery Tender are usually avail. at Auto Parts stores.
HOG-I is offline   Reply With Quote
Old 09-27-2010, 10:10 AM   #3
Boulder , Colorado
battery charger
Thanks. I found a 12 volt 1.3 amp batteryminder model that seems like it would do the trick for winter storage. I am assuming if you get a 12 volt with higher amps (like 5 amps) this just speeds up the charging process. Seems like the cost is about the same if you buy 2 single chargers versus one dual charger for the two batteries.
I have experience with the batteryminder from my motocross days so will probably pick one of those up.
Sandy
Solar trickle charger.... drboyd Generators & Solar Power 30 10-22-2019 12:23 AM
Battery Trickle Chargers Devoman Batteries, Univolts, Converters & Inverters 4 04-06-2010 07:09 PM
#2 attempt--any recommendations for a solar charger? Kistler Generators & Solar Power 6 02-16-2005 08:01 AM
toilet trickle want310 Sinks, Showers & Toilets 3 04-29-2003 07:04 AM
Trickle charger to replace Univolt jwaldin Electrical - Systems, Generators, Batteries & Solar 2 02-18-2003 11:12 AM
