05-02-2007, 05:54 AM
Cyclist
2007 28' International CCD
Windermere
Recharge Time
Does anyone have a guestamite as to the time it takes to recharge batteries once hooked back to shore power? I have 2 24R Interstate AS issue batteries on a newer AS.
05-02-2007, 05:59 AM
Retired.
, At Large
At least overnight.
Fully charged would be a specific gravity of 1.275, in order for you to learn how long it would take, you can pick up an inexpensive hydrometer and check the batteries to see how long it takes until they get to the above number.
05-02-2007, 06:46 AM
Naples
It Depends......
.................on your depth of discharge (Terry's hydrometer suggestion comes in here), the rated amp/hours of the batteries capacity and the output (amps) of your charger (converter).
Typically, if your batteries are down 15% and let's say they are 200 amp/hours each, then you need 60 amp hours to re-charge them. If your converter puts out 30 amps, then it will take about 2 hours. This is not exact, but can be used as a 'rule of thumb'.
Make sense?
lewster
05-02-2007, 06:53 AM
Retired.
, At Large
A few years ago, I made an analogy to a milk jug and a straw.
If you have a 500 ounce (amp) milk jug (battery), and you have a straw (charger) that can fill the milk jug at a rate of 10 ounces (amps) per hour, it would take 50 hours to completely fill the jug.
There is a bit more to it than that, as the more fully charged the battery becomes, the slower the charge rate, but most non-technical people can understand this analogy.
05-02-2007, 06:54 AM
Naples
Simple is GOOD. Nice analogy!
lewster
05-03-2007, 08:31 PM
New Borockton
, Alabama
With no resistance from the battery, this is a good rule of thumb. Problem is that the charge rate (Amperage) drops off as the batteries charge because the internal resistance builds in the batteries. The first couple of hours on a discharged battery, you will see virtually all of the rated output of the charger going to the battery (sometimes more). With that logic, you can look at your watch and predict when you will be fully charged. Not quite though.
After a few hours, the rate tapers off and it can take even a couple days to reach full charge, depending on the charger type, Amp hours, etc.
Many of the newer chargers have a bulk or boost mode that raises the voltage (Pressure) to overcome the resistance and continue to deliver higher amperage for a period. This is typically limited to 4 hours or so for a couple of reasons. First, at 14.4 volts, the batteries will gas and gassing causes a loss of electrolyte. This is necessary for a full charge but must be regulated. Also, charging an already fully charged battery at 14.4 might overcharge it and lead to early battery failure if don't too often or for too long.
Most of the manufactures have settled on a max of 4 hours for bulk charging but you could argue for more or less. I argue for less as we get several calls a week from people complaining of sulfur smell, and over charged batteries, mostly from the inteli-power owners that won't leave the charge wizard button alone to do its job. Not you guys of course, SOB owners, haha.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
05-03-2007, 10:50 PM
Retired.
, At Large
I mentioned the lowered rate as the battery charges, I just didn't want to get too technical. We don't know if the person asking is an electrical engineer, or somebody that doesn't know an electrode from an electron.
05-04-2007, 06:04 AM
Naysayer
1968 24' Tradewind
Russellville
, earth
A which from a what?
05-04-2007, 06:06 AM
Naples
Sur are an awful lot of 'Es' running around in this post!!!
lewster
05-04-2007, 06:12 AM
Retired.
, At Large
Looks like one less than there should be...
My speel chequer let me know about it when I quoted it, too! Hee hee...
05-04-2007, 11:06 AM
New Borockton
, Alabama
By golly you did say that Terry I know what you mean about those E's Lew. Some double E's call me but don't tell me they are a double E until the end of the conversation.
888-828-1893
Bestconverter.com
05-04-2007, 04:04 PM
West of Fort Worth
A preacher I know says that if you speak so the youngsters "get it", then everyone else will too.
I can handle simple.
Dave
05-05-2007, 06:49 AM
2007 19' Bambi
Ottawa
, Ontario
Make sense?
Henw mentioned he has a newer AS. So I'm assuming he might have something like I have, a Parallax Model 7355, 55A converter charger.
I brought my batteries down to 50%, hooked in an amp meter, and connected to shore power. The meter showed about a 4.5A charge. Now I know putting in that meter does drop the voltage so my real charge rate removing the amp meter might be 5 or 6A (I'm guessing), but still thats a long way off the ideal of a 16A charge for a C/10 rate on my 2 X SRM-24 batteries (82AH each). In order to make charging with a generator more efficient, does this mean the Parallax that comes with the AS isn't the best option for charging?
05-06-2007, 02:10 PM
New Borockton
, Alabama
Your 7355 is capable of charging at 55 amps. Whether or not it will is determined by the batteries. 50% discharged, I would have predicted more than 5-6 amps initially but then it will taper off rather quickly with a constant voltage of 13.8. For faster charging, you will need a boost or bulk mode to force the current into the batteries faster.
I don't get too wrapped up about the C/10 ratings anymore with voltage regulated switching converters. Years ago, it was extremely important. Still, the only real concern in charging too fast now is heat and I suppose there is some trade off in recharge cycles but not much. 125 degrees is a common limit for some of the battery manufactures but with healthy batteries, I never see excessive heat build up. One bad cell in the battery bank and all bets are off!
Believe it or not, the 7300 Parallax is a well regarded converter with a low failure rate but it is not known for fast charging and might cause your batteries use excessive water in the summer months at 13.8 volts.
888-828-1893
Bestconverter.com
05-06-2007, 05:23 PM
Surprise
Originally Posted by 68 Overlander
...For faster charging, you will need a boost or bulk mode to force the current into the batteries faster...
Can someone (68 Overlander or ???) be more specific about how this would be done? Connect a faster charger directly to the battery terminals? If so, is it necessary to disconnect the batteries from the trailer?
Titus
05-06-2007, 05:56 PM
Pittsfield
, Maine
On the subject of battery charging, I've noticed that, when stored for the winter, the idiot lights in the Airstream will show a full charge for several weeks and then, from one day to the next, drop to 1/4 charge or less. I've yet to see a 3/4 or 1/2 charge indication. Once the indicator does the death spiral, I plug the trailer back in and leave it for a week or so. Afterwards, it's good to go for anywhere from 2 to 3 weeks during the winter months. I plan to buy a cheap solar charger to stop the YoYo effect. During the summer the trailer gets enough use on the road or plugged in to mitigate any significant discharging.
Cracker
05-06-2007, 06:26 PM
Naples
Titus
Titus,
I believe that Randy was referring to the first charging stage of a 3-stage charger....the 'bulk' charge phase. This is done at the highest voltage (dependent on the battery type)) as the initial 'boost' for the battery. Each successive stage (equalization and float) produce less voltage with the float charge being a 'maintanance' charge.
Hope this helps!
lewster
05-06-2007, 09:16 PM
Surprise
Titus,
I believe that Randy was referring to the first charging stage of a 3-stage charger....the 'bulk' charge phase...Hope this helps!
Aaaah, yes! A very helpful comment, Lewster, because I misunderstood the earlier post. I now see that the point was that battery charging could be improved by replacing the existing converter with a new, more sophisticated one (3-stage). But I mistakenly thought the point was that the batteries could be charged with a separate, "free standing" battery charger (also of the 3-stage variety). In other words, not an RV converter (which charges and distributes power to the trailer), but a completely dedicated battery charger. Hence my question: If you want to use a super sophisticated charger (as distinguished from an RV converter), should you disconnect the batteries first?
Let me rephrase the question now: Does anyone use a "free standing" (that is, a separate) battery charger to charge their batteries? Or, do people who want faster, better charging just replace their existing converter with a new (and presumably better) one?
I guess the reason I'm curious is because...well, because I'm becoming a little cynical about the quality of the components that are used in our trailers. I'm afraid I'm just not convinced that any of the RV converters are really as good as the best battery chargers. Please tell me I'm wrong. Then please also tell me that upgrading to such converters is both cheap and easy...and that I wouldn't be stupid if I performed such an upgrade on the brand new AS I just brought home a few weeks ago!! I'm tired of waiting several lifetimes for the batteries to recharge from my Parallax converter, and I'm...uh, I'm trying to be tactful here...I'm a little disappointed that AS charges top $$$ for its products but relies on less than leading edge converters.
Thanks!
Titus
05-07-2007, 05:47 AM
Naples
Titus,
I'm with ya! The FIRST thing I did was to replace the OEM Parallax with a WFCO converter, on the understanding that their charge circuitry was superior to the P-lax. So far I have not been dissapointed.
That said, I HAVE used an auxiliary charger on ocassion also and when I did, I disconnected the negative lead from the batteries that go into the trailer to isolate them. This as a safety measure so as to not give the converter any voltage feedback and to assure that ALL of the charger's output is going to the batteries.
I want those 2-6VDC Lifelines FUUULLLL!
lewster
05-07-2007, 06:03 AM
2005 22' International CCD
Woodland Park
Titus,
I did the same as Lew; just this weekend installed a WFCO 3 stage charger (Parallax conversion) and Trimetric battery monitor. Bought it from Randy at bestconverter.com. Very easy install on both, true 3 stage charging and the Trimetric allows me to keep accurate track of my battery bank and power usage. Highly recommend both. jk
