Old 10-03-2015, 05:10 PM   #1
2007 19' Safari
Tempe , Arizona
Re-charging batteries
I inadvertanly left our AS "in use" mode and now the batteries are dead. If I plug the AS into shore power to re-charge the batteries, do I put the battery disconnect switch in "store" or "in use" mode?
JB Riveted is offline   Reply With Quote
Old 10-03-2015, 06:05 PM   #2
2015 25' FB Flying Cloud
Eugene , Oregon
"Use" mode will enable the converter/charger to charge the batteries when the AS is plugged into shore power. More specific info is in the Airstream manual.
Take care,
Chris
Meeks is offline   Reply With Quote
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 28 12-16-2017 06:32 AM
Batteries not charging while driving wildwoodrver Electrical - Systems, Generators, Batteries & Solar 36 08-22-2008 05:33 PM
Charging Auxiliary Batteries COLORADO_CAMPER Batteries, Univolts, Converters & Inverters 9 06-09-2008 10:16 AM
GMC Diesel and charging batteries while towing SRoffe Mechanics Corner - Engines, Transmission & More... 17 09-17-2007 08:28 PM
Charging AGM trailer batteries from vehicle mswartz Batteries, Univolts, Converters & Inverters 5 05-15-2004 02:34 PM
