Old 08-30-2016, 07:16 AM   #1
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Rats nest in battery box
(Copy of my post in another thread)
"Inspired by Rocinante - no real name given.
Made a count of the individual wires making up my battery box rats nest.
Emergency brake
Jack
Back up camera
TST TPMS repeater
Two mystery wires that lead inside the trailer
Positive and ground main battery cables
Tomorrows project is a small marine junction box mounted on the side of the battery box with one wire leading to the battery positive post. I found one in my box of swag from my sailboat cruising days that will work nicely."
Question for the pros,
What size wire should I use from the battery to junction box?
MICHAEL
Old 08-30-2016, 07:21 AM   #2
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Good Idea!
I have a bit of a nest starting in our battery box also. Will be interesting to get input on wire size.
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 08-30-2016, 08:08 AM   #3
1959 24' Tradewind
Heber , Utah
I used six gauge on mine but I know 10 gauge should be enough be enough it all depend on how must stuff you plan un using. 10 gauge will handle 30 amps.
shinytincans is offline   Reply With Quote
Old 08-30-2016, 08:37 AM   #4
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
My suggestion: I suspect we're only talking about a couple of feet between the battery box & new junction box, but voltage loss is voltage loss and the cost of a short cable like that shouldn't be a show-stopper. So, within reason the thicker the wires (one black and one red?) from the battery box to your new junction box, the better. For starters, I'd suggest they should be at least as thick as the main house wires that go to the battery box right now, and maybe one gauge thicker. What gauge is that wire?
Rocinante is our 2014 International Signature 27FB
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
Rats, broken shock mount dbj216 Shocks 7 07-04-2009 05:01 AM
Rats!! warnicks Member Introductions 12 03-09-2008 06:23 PM
The Rats ate it. jt6128 Interior Restoration Forum 6 03-21-2005 01:56 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
