04-14-2009, 08:14 AM
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain
, Ohio
Quick probably dumb univolt question!
Ok, My son and I are having a pleasant arguement. (He's probably right, but I would admit it.)
Is a 1970 univolt suppose to "run" while only hooked up to a TV? No battery is installed. The shore power is not plugged in. The ground wire for the 110 breaker panel is not connected to the frame.
So did I screw something up?
04-14-2009, 08:39 AM
1967 22' Safari
1960 Caravel
Edmonds
Hi DanB, The univolt is not suppose to run while hooked up to TV. Your TV will maintain the trailer battery while towing. Install a battery. The system is not meant to run without a battery. The univolt converts shore power(120v) to 12v through the univolt. The ground should be connected to the frame. Don't confuse the the 12vdc and the 120vac circuit.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
04-14-2009, 09:04 AM
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain
, Ohio
So when I'm at a rest stop, I pop inside the trailer for a cola. I turn on the lights. I am running off of battery. And the battery is being charged via TV.
So as long as I have a battery in the circuit, I will have light. Correct?
I try not to confuse the DC and AC system. I find doing that causes pain.
I just wanted to provide all the facts!
Thanks!
04-14-2009, 09:16 AM
1967 22' Safari
1960 Caravel
Edmonds
If your trailer is wired correctly you will get a "trickle" charge from the TV. The battery if charged will give you power to the 12v lights even if your not plugged into the TV or shore power. "trickle" The wire from the TV charge system isn't that big and doesn't give your trailer a big charge. It will kill the TV battery if you leave it plugged into the TV over night.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
04-14-2009, 09:31 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
well....no, it won't. Unless, I suppose, you leave all the lights on in the trailer, and the radio blaring, and the furnace running, etc, etc.
If you stop at a rest stop, with this particular trailer, as it stands (no battery), and you turn on a light in the trailer, and see that it works...its getting its power from the tow vehicle.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
04-14-2009, 09:35 AM
1974 27' Overlander
Grants Pass
, Oregon
Newbie??
talk about newbie.. I'm sitting here reading this post, hoping to learn something as I usually do and wondering what plugging in a television will do to the univolt.. Boy, do I have a ways to go.. Guess I forfet a rivit.
Lee
NI7I
04-14-2009, 09:41 AM
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain
, Ohio
Don't worry about it. I've been on here several years, owned an airstream, and can't figure out what my Univolt is supposed to do when!
Also, I did the same thing with "TV" not long ago!
04-14-2009, 09:44 AM
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain
, Ohio
Is this even possible?
04-14-2009, 09:54 AM
1967 22' Safari
1960 Caravel
Edmonds
I think so, although Chuck doesn't. Is it worth the risk? If your not plugged into shore power you will be drawing some off the TV battery. Given the right circumstances you can kill the battery in the TV. Yes, it is slim...
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
04-14-2009, 09:55 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Possible? um, yeah. broken, if it doesn't work this way.
Ok, let me just qualify it a bit: depends on the "tow vehicle". (didn't say "TV").
On some trucks, the battery charge line is always hot; in others, its only hot if the tow vehicle has the key in the "on" position, and/or engine is running.
mine is always hot.
when that line is hot, 12v is being fed to the trailer's 12v system, just as the univolt does it, if its plugged into shore power. having the tow vehicle and trailer connected essentially "joins" their electrical systems. plug in the univolt to shore power, with the tow vehicle hooked up, and ITs battery will get a charge from the univolt, too.
Air:291
Wbcci: 3752
'73 Safari 23'
04-14-2009, 09:59 AM
2006 30' Classic S/O
Mohrsville
, Pennsylvania
Lee
NI7I
Lee and Dan,
The univolt / converter charger is responsible for taking 120 VAC and running your 12 VDC systems (most lights, furnace, 12 volt circuit of refrigerator, radio, 12 volt circuit of water heater etc...) and keeping the batteries charged.
Your 120 VAC appliances (TV, microwave, toaster, coffee pot, etc...) will ONLY run when plugged into 120 VAC shore power (that is unless you have an inverter which is a whole other bucket of worms).
When boondocking the univolt / converter / charger does nothing and you are drawing totally on the 12 VDC of the coach batteries.
When hooked up to the tow vehicle your vehicles battery and alternator provide the current to help run the 12 VDC things and trickle charge your coach batteries.
Univolt / Converter / Charger changes 120 VAC to 12 VDC.
Inverter takes 12 VDC and steps it up to 120 VAC.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
04-14-2009, 10:03 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
{mass confusion}
I agree with this statement. But this is not what you said before.
you said: "It WILL kill the battery". <----that is not true.
It could kill it. not very likely, unless you are using lots of electricity all night. The sentence previous to "it will kill the battery" implies that all it would take is the draw from the trailer's battery....that isn't true, either. On many occasions, I've started to run low on amps while boondocking, and have plugged the trailer into the truck for a little boost, just to get by until morning. never a problem...truck starts right up the next day.
Now, I wouldn't do this if I were alone and isolated...but with a group, or at a campground, where a jump is available if needed, no worries.
Air:291
Wbcci: 3752
'73 Safari 23'
04-14-2009, 10:32 AM
1967 22' Safari
1960 Caravel
Edmonds
No confusion. I just like to play it safe. Posting is interesting thing. Some times your not as clear as you think you are. Maybe I should just leave it to someone else.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
04-14-2009, 10:49 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
...Maybe I should just leave it to someone else.
NO!
its the "discussion" that makes the forum so valuable. input from everyone!
Air:291
Wbcci: 3752
'73 Safari 23'
04-14-2009, 11:49 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
part of the equation is understanding just how much each device consumes.
we all know that leaving your headlight on overnight will usually result in a dead battery by morning. in the trailer, the heater fan is the big hog, followed by electric fans and a few regular light bulbs.
think of a battery like a checking account, if you take out too much, you're in trouble. you also want to keep the batteries from going below 50% to prolong battery life.
the univolt is more to maintain the batteries than to charge them up from dead.
Ricky
04-14-2009, 12:30 PM
1993 34' Excella
Estancia
, New Mexico
Lee
NI7I
Are you talking about a 110v or 12v television, or a 110 TV run through a 12v inverter? But, neither will do anything to the Univolt. The 110 runs on shore power. The 12 v runs off the battery. Another factor for running a television off the battery is what is the amp/hour rating for the battery. Your average single series 27 battery is probably good for a couple of hours of TV watching.
04-14-2009, 12:54 PM
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain
, Ohio
Lumatic,
I believe he he mistakingly confused "TV" for television instead of "Tow Vehicle".
I've caught myself doing that also!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
dumb question
bimpy |
Furnaces, Heaters, Fireplaces & Air Conditioning |
4 |
07-23-2007 01:33 PM |
Dumb Question
fr8tshaker |
Off Topic Forum |
17 |
05-04-2006 05:31 PM |
I have a dumb question
C Johnson |
Our Community |
2 |
02-22-2005 10:48 PM |
Dumb question here...
Minnie's Mate |
Our Community |
5 |
08-31-2004 10:01 AM |
