Old 06-23-2019, 06:55 AM   #1
cptdzl's Avatar
2018 27' Flying Cloud
Erie , Pennsylvania
Question? Replacing factory converter & inverter with 2k watt inverter charger
My prior RV experience is a coach with no converter. It had a Inverter/charger with built in transfer switch & smart charger. Plugged into shorepower main panel would feed the Inv/chgr and it would feed a sub panel for designated outlets (tv, microwave, misc outlets) and it would smart charge (3 stage) the batteries and all 12v ran from the battery bank. No high draw items where in the sub panel (AC, water heater, etc). When unplugged the inv/chgr would sense no 120 shore and take over in milliseconds to provide 120 through a sub panel to those circuits. Has any one else done this on their trailer? Thoughts? Opinions? am I missing anything else? I have factory solar and plan on experimenting with different battery types and ultimately upgrading to Lithium. (inv/chrg has programmable battery charge profiles so it can handle the specifics of lithium and others) Keeping the batterys charged is not the concern, combining the 2 separate factory systems is.
EXPERIMENTAL based on untested ideas or techniques and not yet established or finalized
Rick & Becky
2018 FC27FBQ
2018 RAM 1500
KD3OBX 146.520
cptdzl is offline   Reply With Quote
Old 06-23-2019, 07:55 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Many of us have done this. I used all Victron equipment. You will find a number of threads with our experiences.
Larry
lsbrodsky is offline   Reply With Quote
prep for my solar future: Inverter charger/inverter-converter combo wonderlust87 Electrical - Systems, Generators, Batteries & Solar 1 09-13-2017 10:50 AM
6 months with the AIMS 2000 Watt Pure Sine Inverter Charger trekerboy Batteries, Univolts, Converters & Inverters 9 07-10-2017 07:17 AM
Factory 1,000 watt inverter rp709 Batteries, Univolts, Converters & Inverters 62 10-16-2014 09:20 AM
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 10:21 PM
Replacing Parallax converter with Xantrex Inverter/Charger worksology Batteries, Univolts, Converters & Inverters 22 01-22-2011 08:59 PM
