07-03-2014, 07:37 AM
2013 25' FB Eddie Bauer
St. Albans
, Vermont
Question re battery level while dry camping
New owners. We recently spent 9 nights dry camping at a Vermont State Park with our 3 Small grandkids. Prior to this trip we had only camped with hookups for three weeks back in May. Water management went well as we used the park showers and restrooms. However, we had problems managing the battery level using our 1K Honda twice per day during gen hours. Each time we were only able to recharge them to 12.5 or less. We used power sparingly - only fridge and a quick flick of lights to find their pajamas. No radio, tv, chargers, fans etc. each morning the level was down to 12.0. Is this normal? Solar in our future but right now we would like to dry camp for 3 or 4 nights and the gen doesn't seem to give us enough of a charge to enable us to use anything without sending the levels below 50 percent. Advice? Incidentally, had a blast and the kids did too!
07-03-2014, 07:46 AM
Oswego
Based on what you state, doesn't seem normal.
I assume two OEM Interstate batteries?
How long did unit sit on dealer's lot prior to purchase....or do you know history of storage?
Have batteries been run down to below 12.2V many times or been fully depleted?
Has water level been consistently maintained over life?
Original OEM single stage converter installed and been plugged into shore power continuously over life?
I suspect marginal batteries, as you can tell.
-Rich-
07-03-2014, 08:33 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
are you charging the trailer with the trailer converter or a 12v output from the generator? the generators don't give you much in 12v output.
Ricky
07-03-2014, 10:57 AM
1974 Argosy 20
Kooskia
, Idaho
I also would suspect marginal batteries. Your refrigerator and water heater both take 12 volt power to operate so there is some drain even though you may not be aware of it.
As dzn mentions, the batteries could have been abused prior to your ownership, or run down and not recharged promptly. Batteries do not tolerate being left discharged or partly discharged very well, and lose the ability to be recharged fully.
You didn't say how long you ran the little Honda either. With a badly discharged set of batteries, even through the converter/charger in the trailer, it would take several hours of run time to bring them back.
07-03-2014, 01:00 PM
2011 23' FB International
2007 20' Safari
Irvine
When I purchased my new 23' Serenity from dealer, the unit was sitting on his lot for over 10 months, and on my request the dealer replaced the batteries with out any fuss. Your dealer should be able to replace your batteries after all he made substantial amount of commission on your unit.
I also bargained a 50 Watt solar, however, in your case it may be too late.
Good luck
07-03-2014, 08:49 PM
St. Albans
, Vermont
Thanks to all for responses. In checking with dealer we learned that batteries were replaced last Oct when unit was stored indoors for winter as originals were worn from people flipping on inverter while looking at it on lot (5 months). We did charge through convverter each day for 3 hours. After moving to hookups for 3 nights then driving home it now reads 12.9. We will try some driveway camping to use batteries and generator and will see what happens and report findings.
07-03-2014, 09:27 PM
2008 27' Classic FB
Hutchinson
I to have had issues with boondocking on batteries. I try to be very frugal with my 12 volt use and find that 2 days is about it. I took both my batteries to O'Reily Auto Parts and had them do a battery load test. They said both batteries were good. I also put both batteries on a de-sulphuring battery charger. Does anyone know if this procedure and test are reliable for determining the health of the battery?
07-03-2014, 11:03 PM
1974 Argosy 20
Kooskia
, Idaho
The battery voltage will tell you the state of charge of the battery, but will not tell you the capacity of the battery overall. Imagine a little battery and a big battery, both new. The big one will have more capacity than the little one, but they will have the same voltage when fully charged.
Unfortunately, a big battery can become effectively a little battery in capacity by miss use and being stored undercharged. This can happen very quickly. The plates sulphate, and once sulfated essentially the capacity is permanently reduced. So even though the batteries in your trailer were replaced last fall, they still may have suffered greatly over the winter, if left undercharged, or discharged.
All of this is a guess, a possibility as it is not easy to test overall capacity of a battery. See how it (or they) preform in your driveway testing. See if they run down quickly, then recharge quickly. If they do, you may be replacing them again even if they are fairly new as they have little capacity, no matter what the voltage says.
07-07-2014, 07:38 AM
St. Albans
, Vermont
Driveway test of battery life - after charging with plug we disconnected and battery showed 13. We only left power on to propane fridge - nothing else used (radio off) - only parasitic drains. After 12 hours dropped to 12.5, 24 hours to 12.3, 36 hours to 12.2. We reconnected to shore pwer at that point to avoiding dropping below 50 percent. Is this below expected battery life? Thx
07-07-2014, 10:09 AM
1974 Argosy 20
Kooskia
, Idaho
Yes, well below battery life expected. Your two type 24 batteries should have a capacity of 150 amp hours total, maybe 160 max. If all you had on was the refrigerator your load was well under an amp. In my 2014 the refrig takes only 0.32 amps when the flame is on. Yours should be similar, maybe a slightly bit higher, lets say half an amp. 0.5 amps x 36 hours = 18 amp hours of draw vs. the 150 amp hours of battery capacity. That would surely indicate a battery issue.
The only other thing I can think of is some unseen load like an inverter left on by accident, or a defective converter/charger which when shut off puts a reverse load on the system. Do you have an inverter? Is it off?
If there is any way for you to get a small test meter with an amp range on it, you could disconnect one of the battery terminals and with everything off that you know of, measure to see if there is any current flow, indicating an un identified load.
You should be in warrantee still, so maybe a trip to the dealer is also something to think about.
07-07-2014, 11:54 AM
2004 16' International CCD
Chicagoland
It sounds like your batteries might be getting weak. Nevertheless, I wonder what other loads might be "on" without your knowledge. If you have a propane, smoke, and/or CO detector they might be pulling some current too. Does the converter pull a few amps even when it isn't loaded? Maybe there is a light on in a storage area that you wouldn't normally see?
As idroba suggested an ammeter should help you quickly isolate the problem. If you don't have one, and are considering the purchase of one, you might look at a clamp-on unit to make the job easier, safer, and quicker.
07-07-2014, 11:59 AM
1974 Argosy 20
Kooskia
, Idaho
Unfortunately clamp on DC ammeters for the 12 volt side are fairly rare and costly and not that reliable. I have one and find it to be a PITA overall. AC clamp on meters are great though.
07-07-2014, 12:20 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
do you have a subwoofer? if so it is probably always in the 'on' position.
Ricky
Oswego
Unless he has the cutoff switch off, there are a few more parasitic loads besides fridge. CO detector, radio head, thermostat, fridge fan????, some monitors?????
OP should shut off the 12V cutoff switch and repeat test. The only parasitic load then, assuming wired similarly to mine, would be the CO detector....and that could be eliminated by removing it's inline fuse. On mine, that is an orange wire and the fuse is in the rear of the electrical center.
Still seems like a premature rundown to me though.
-Rich-
07-07-2014, 12:23 PM
2016 25' Flying Cloud
Sunnyvale
Just one additional thought on the generator, though it does sound like there is current drain somewhere in the system.. The Honda 1000 is really only producing 7.5 Amps into the Charger/converter, and some of that is going to be available for 120 V AC needs.. (Most refrigerators will switch to Electrical mode from Propane mode if they sense 120V AC Current available...). Net result is that charging time using a Honda 1000 is going to be more than a couple hours, if batteries are really low..
Condoluminum
07-07-2014, 12:31 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
is the power on to the tv antenna booster?
Ricky
07-07-2014, 08:14 PM
Mohnton
, Pennsylvania
Reading this topic with great interest & agree check TV antennae booster as we have already realized when mistakenly left on was big parasitic drain. We've been driveway testing & have not yet enough experience regarding amount of time needed to recharge batteries with 2000 generator. Since we have our first long NY State Park trip planned to Adirondacks 12 nights w/o hookups...trying to understand approx. how many hrs. we will need to run generator to reboot batteries each day. Park rules only permit generators 7-11 am & 4-8pm.
07-08-2014, 08:31 AM
St. Albans
, Vermont
Power off to antenna. Re generator - would it be suggested that we turn off the fridge during gen charging hours? Are we able to shut off subwoofer battery drain? We are borrowing annemeter to test batteries. Then back to the dealer.
07-08-2014, 08:51 AM
Alamo Heights
You don't have to turn OFF the fridge, just set it to Propane instead of Auto. I've read that when the modern ones are set to gas-only it's a testing mode and they stay on and can over-cool but that's complete hearsay, I have no personal experience with the newfangled models with 12v power and control boards.
— David
07-08-2014, 10:39 AM
1974 Argosy 20
Kooskia
, Idaho
On my 2014 FC 20', when you push the GAS button, it forces the refrigerator to propane, but also, for reasons only known to Dometic, bypasses the thermostat, so it stays on full time, and could freeze things in the refrigerator. My dealer told me that, and I later found it confirmed in the Dometic book which came with the trailer. So, the only way that you can force my unit to propane and still have thermostat control is to either unplug the refrigerator from the wall outlet in the back, or shut the circuit breaker for that plug off. Doing that would allow the little 1000 watt honda to give all it's output to the charger though. Your refrigerator in your EB could be different, Dometic has made a lot of variations on their refrigerator control systems.
The antenna amplifier should not be left on when the rig is not in use, but takes a very small amount of power and will not be the cause of any battery drain of any significance out camping. Same with the CO detector.
I tested the sub woofer on my trailer, and it has zero drain when the radio is not on, so again, I don't think you have a problem with that either.
The only real way to test for an unknown drain on the batteries is with an ammeter checking either the total battery draw down (disconnect the battery negative terminal an measure the current draw) or test each circuit by removing the fuses one at a time and looking for an unexpected load.
If you find none, I still believe you have week batteries which have no real capacity, as shown by your voltage test drawdown, listed in your post above.
