Old 10-24-2010, 12:55 PM   #1
2008 23' Safari FB SE
Boulder , Colorado
Question on trickle charging 2 marine deep cycle batteries
We just removed our 2 12 volt batteries from our AS and also have purchased a battery minder trickle charger.
The batteries are now in the garage and wired in parallel. I notice that the instructions seem to say to attach a 24" 6 guage AWG wire to the negative post before connecting and charging with the trickler. Is this required to "ground" the batteries while out of the AS?
Also - it says something about refilling the batteries with water but I don't see any water line or water inside the marine batteries. Am I just missing it? Each battery does have 2 caps on top with 2 holes inside each cap.
Thanks.
Sandy
bonginator is offline   Reply With Quote
Batteries..basic charging question Delaware Batteries, Univolts, Converters & Inverters 3 11-16-2009 01:19 AM
Deep cycle battery - unexplained power drain Al & Marilyn Batteries, Univolts, Converters & Inverters 3 09-17-2008 06:56 AM
Deep cycle battery switch jaiman Classic Motorhomes 3 07-23-2005 01:28 PM
Which Deep Cycle Battery? boltos Batteries, Univolts, Converters & Inverters 26 12-07-2004 05:57 PM
deep cycle battery replacement 26Argosy.ca Electrical - Systems, Generators, Batteries & Solar 6 01-02-2003 05:19 AM
