Old 05-17-2008, 07:04 AM   #1
1998 31' Land Yacht
Ottawa , Ontario
Exclamation Prosine 2000 / Batteries
Hi,
Place my Airstream landyacht in storage for the winter and was changing for 4 months. I had the disconnect off.
The coach batteries were fully charged but the motor battery was dead. Can someone explain why this happens and/or a solution.
Marc
Marcblou is offline   Reply With Quote
Old 05-17-2008, 07:12 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
Is your charging system set up to charge the engine battery along with the RV batteries? If not, the answer is obvious. If the engine battery was charging, the condition of the engine battery may have been poor going in. Did the engine battery take and hold a charge affter you found it depleted.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 05-17-2008, 12:13 PM   #3
1998 31' Land Yacht
Ottawa , Ontario
The motor battery kept it charge after being recharged.
Marc
Old 05-17-2008, 05:07 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It was drained both by parasitic draw, and normal natural discharging.
Parasitic draw is that from the engine computer and other things like the radio memory and clock.
Normal discharge is about 25% of charge over a three month period. Cold weather accelerates the process. To slow down the drain next fall, unhook the negative terminal from the battery. It will still discharge, but not as fast.
Old 05-17-2008, 07:35 PM   #5
1998 31' Land Yacht
Ottawa , Ontario
Hi,
Thank you very much guys. I will disconnect the negative terminal.
Thanks again
Marc
What is 2000 Safari 25 worth? idahosafari 2000 Safari 2 10-12-2015 12:59 PM
2000 Land Yacht ?? ghorne General Repair Forum 0 11-27-2007 05:40 PM
2000 Safari 25' gowyn Trailer Values 11 09-16-2007 09:45 AM
Time for that second Honda 2000 Raptorrider2001 Our Community 2 06-17-2003 05:57 PM
