Old 10-12-2011, 07:07 PM   #1
2004 28' Safari
Billings , Montana
Propane detector
Hi My wife and I just bought a 2004 28' foot safari. I have a question on the propane detector. If I have the battery disconnect on store will the propane detector still draw power from the batteries?
My other question is how do I contact other airstream owners in my home state of Montana?
We are really excited about our airstream and I am learning a lot from the airstream forums.
travelcats2 is offline   Reply With Quote
Old 10-12-2011, 07:17 PM   #2
dznf0g's Avatar
Oswego , Illinois
My detector was wired around the power shut off switch. That is, it was live all the time the batteries were hooked up. I think that is code. I moved my detector power supply into the into the fuse block so now it shuts off with the cutoff switch.
Some will tell you that having them not powered of periods of time will cause false alarms, but I have not experienced that in the last year, including 5 months in storage.
Old 10-12-2011, 07:19 PM   #3
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
We just bought a 2002 25 foot Safari. It has a solar panel on the roof. I have noticed that when I turn the battery switch off that the propane detector has a light that continues to flash. I have not done any research on this yet. Are you experiencing a similar light flashing on the propane detector with the battery switch off?
Ridgerunner3 is offline   Reply With Quote
Old 10-12-2011, 07:21 PM   #4
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I know that the propane detector on mine does remain connected to the battery even though the battery disconnect is active. The load is minimal, but could be considered a parasitic drain. For seasonal storage, either disconnect the battery physically or if possible, provide a way to charge it monthly. The CO and smoke detectors have their own batteries. I remove them and the water filter battery when I winterized the trailer to avoid any battery leakage damage.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 10-12-2011, 07:25 PM   #5
dznf0g's Avatar
Oswego , Illinois
Don't forget the doorbell batteries!
Old 10-12-2011, 07:52 PM   #6
2004 28' Safari
Billings , Montana
propane detector
Ridgerunner, I do not have any lights flashing on the detector when I have the battery disconnect on store.
Old 10-12-2011, 08:37 PM   #7
dznf0g's Avatar
Oswego , Illinois
Then it's wired downstream from the disconnect switch and it does not draw power when the switch is in the disconnect position.
propane gas leak (rotten eggs) 2010 International stench wendywoods LP Gas, Piping, Tanks & Regulators 20 12-01-2011 02:34 PM
Propane phobia. ROBERTSUNRUS LP Gas, Piping, Tanks & Regulators 18 04-27-2011 11:37 AM
Propane go boom SpaceEgg LP Gas, Piping, Tanks & Regulators 4 02-28-2011 12:05 PM
Propane detector disconnect airhaus LP Gas, Piping, Tanks & Regulators 7 01-11-2011 01:09 PM
