12-06-2017, 11:55 AM
2016 19' Flying Cloud
San Francisco
Progressive Dynamics Converter - Thoughts?
Hello Air Community Crew,
Seeking some feedback on Progressive Dynamics Converters. Here's my specs of current set up:
2017 19' Flying Cloud - standard converter
Zamp 100w Expandable Solar Panel - installed earlier this year by Airstream
(2) 6-volt Trogan batteries
During recent visit to folks, I plugged into land power; done this every visit. This time, the converter fan ran 24/7. I did some reading on the forums and saw feedback regarding a possible charging issue.
Airstream said this was normal, but I disagreed as I noted all trips in a year, plugged in at RV parks, the converter fan only came on with converter was warm. Even with the new solar, the converter fan ran intermittently, but this time, non-stop; whether in Use or Storage position on the switch. Once unplugged, the fan would stop.
I work with my local Airstream dealer/service center in Fairfield CA; apparently the largest Airstream service center in the US. Chris, love the guy, says, best to switch out the converter to a Progressive Dynamics. He and his crew have never like the standard converter that came with the trailers. This would be a benefit as whether in Use or Storage, once the batteries are charged, the converter stops running a charge through the system.
This has become standard practice at their center for new purchasing; upgrading the converter from the start. He noted Airstream comes to them regularly, as often the Fairfield Center (Airstream Adventures) does upgrades that later end up in Airstream production. Airstream insisted they use a US maker which PD is. Now, the 2018 models are coming out with a better converter in them.
So, just seeking some feedback. The converter is $367 and install is $250. Figure let them do it, it would be under warranty and guarantee, and I don't have to worry about overcharging.
12-06-2017, 01:26 PM
2000 30' Excella
Toledo
, Ohio
I put a Progressive in my Airstream this past year mine is the deck mount I don't remember what model it is , it does have the charge wizard with the pendent . I bought directly from Progressive . Shipped it was a little over $200. I installed it myself mine was under my couch , that was the worst part of the job removing the couch . It's a simple install . and so far no over charge of the batteries . My trailer is in storage for the winter so I can't give you much more info at this time .
12-06-2017, 01:36 PM
1955 22' Safari
Laredo
Good plan to replace the battery boiling original converter. Your batteries will thank you and it will be a net savings over time as the batteries will last much longer.
As long as you have access to the existing one, this is a very easy installation and their pricing is quite high for parts and labor. Buy direct and install yourself to save $$.
12-06-2017, 03:03 PM
2015 30' Classic
Pleasanton
Whether or not the fan is running is a red herring. The fan kicks in when an internal temperature sensor says so. This doesn't mean your converter isn't working properly.
Your converter operates as a single-stage battery converter. This isn't great, but you have a solar charger. By selecting the "store" position when you're connected to shore power for extended periods you can avoid the potential harm that can occur from a single-stage battery charger by disconnecting your batteries from the converter.
I do this myself and will be coming up on three years with no battery issues. So my advice to you is to save yourself $500 and switch to store mode when connected to shore power.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
12-06-2017, 03:24 PM
1994 34' Excella
Warren
, Manitoba
I have installed 2 Progressive units in 2 of my trailers, both PD9245's. Have installed several more for friends and have had ZERO problems. Great units and easy to install.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
12-06-2017, 03:45 PM
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Bay Area AS Adventures...Chris and Josh are great!
There are several threads in past couple months on this issue/question. My buddy just got his 2017' 23D back from Fairfield dealer after having issues with his second set of Interstate batteries; the new ones would not get past 10V this past week while camping...turns out the converter was bad. He called AS in Fairfield, and they replaced his stock single stage unit, with Progressive Dynamics PD4635 4 stage converter. Told him he could leave it plugged in and not worry anymore about his batteries being over charged. Frustrating I know, but that's the current state of things if you own a 2017 or older unit; the 2018 models come with a 4 stage converter....
I also replaced mine recently in my 2017' FC 28, but I had to get a larger 50A unit, so I installed the Boondocker 1260 from Best Converter...they also sell Progressive Dynamics.
As Fairfield AS recommends, I would replace your Converter ASAP to avoid any issues...unless you want to constantly monitor your batteries with other sensors, heat monitors, etc... I don't want to spend extra time doing this, so the multi-stage converters are the way to go, IMHO...I also installed a manual battery "kill switch" on the batteries to insure there is "no power" going to my AS when I am "storing" for few weeks or more....even when plugged in.
12-07-2017, 09:47 AM
2016 19ft flying cloud
Spokane
When you have them install the new converter, make the investment in a battery monitor at the same time,,,you will be glad you did
Lots of info on the forum on the different monitors available ,,another $200 plus installation
12-07-2017, 10:37 AM
1990 29' Excella
Travelers Rest
, South Carolina
________
I also installed a PD 9245 with the pendant myself, taking pictures of everything as I dismantled the old and hooked up the new. Almost hooked it up wrong, but before I applied power or connected the battery, I carefully went over my photos, and oops. Photos saved my bacon.
I really would have liked the PD 9260 but it draws 1000 watts to run and the PD9245 only drew 750 watts and since I'm a 30 amp system from the post, and already have to manage the frig, ac, microwave/convection, etc carefully and use only certain combinations at a time, I hated to give up even the additional 250 watts of incoming power. My AS is a 1990 Excella 29' and if I had a newer 50 amp unit I definitely would have gone to the PD 9260, but I don't so I didn't. Have been VERY happy with my PD9245 though.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
12-07-2017, 10:42 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
If you just want to spend money, go for it. You already have a multistage converter in your trailer. There are even better converters out there if you want to spend even more money. Unless you add a temperature probe that is located at the battery bank, you really are not doing much of an upgrade.
12-07-2017, 10:46 AM
2004 22' Safari
Albuquerque
, New Mexico
When I bought my 2004 22 foot Safari in 2014, I had read extensively on Air Forums. I bought and installed a PD4645 for $170 (converter cost) and installation was easy and I didn't send myself a bill for installation.
Great product but I have heard they have been discontinued by Progressive Dynamics (presumably replaced by better units, maybe the 9000 series),
The unit has performed beautifully and has protected me from low voltage as well... saving me the cost of units placed at the power box and saving me worry over theft of protective devices used outside of the trailer.
Given the previously limited production of Airstream units, I never understood why they didn't abandon the Parallax unit long ago. Maybe Parallax was owned by a brother-in-law?
12-07-2017, 10:50 AM
, Texas & Wyoming
Not sure why you think you "need" this monitor with a new multi-stage converter installed which monitors your battery charging with intelligent circuitry, like Charge Wizard included with Progressive Dynamics converters? I understand you can get several different battery monitors, at different price points on Amazon starting at $18.00 as example, if you think you need one...
I'm just not sure it is necessary to spend $200 more...assuming the new multi-stage converter does it's job, your stock wall monitor system should be fine. Of course, that's just my 2 cents
12-07-2017, 11:19 AM
1968 22' Safari
Shillington
, Pennsylvania
I installed a Progresive Dynamics, Inteli-Power Charger Wizard 9200 series model number PD9260C, 1000w, 60amp converter with charger in my 1968 Safari 3 years ago. I use a 12 volt Glass Mat battery installed by the factory, don't know the brand. Works flawlessly.
12-07-2017, 12:50 PM
Walnut Creek
Caution - the new 12 volt distribution board which comes with the Progressive unit may have wire connection hardware that is designed for a forked lug connection. If you use a pendant, it is my understanding, that the new board is not required and that makes the install less complex. Designs do change, so this may no longer be a concern. Pat
12-07-2017, 02:17 PM
2019 25' Flying Cloud
Sequim
I installed a PD4655 converter in my 23FB about 18 months ago. I am a moderately skilled DIY'er and it took about 2 hours total. I also installed new AGM batteries a that time. I use portable solar panels on occasion when boon docking. My batteries retain their full charge for 4 - 5 months. I always disconnect the batteries using a $5.00 disconnect switch I bought at NAPA and installed in 15 minutes. This prevents phantom draw from the stereo and LPG detector when in storage. The new converter does not overcharge them.
I purchased the PD 4655 from a vendor in Portland, OR for under $200 (no sales tax in OR) and sold my original converter on eBay for $100 within a week. It works fine - as long as you take time to do all the little things to keep your batteries from boiling. The AGM's and PD4655 made my life much easier!
See http://www.bestconverter.com/PD4655V...l#.WimudLS7_OQ for more info.
D2
"Having differences makes a difference"
12-07-2017, 06:14 PM
2014 27' Flying Cloud
Rancho Cordova
Originally Posted by gypsydad
Not sure why you think you "need" this monitor...
Because I am a little OCD when it comes to 12DC power consumption...
I just love turning something on or off and watching the numbers go up and/or down.
12-07-2017, 06:30 PM
2005 25' International CCD
Fleetwood
, North Carolina
+1 what J-Dog said. But, for us, only matters for boon docking. When we're boon docking and therefore not benefitting from the 120vac-12vdc charge controller, the battery monitor provides us an extremely accurate (and usually, but not always, encouraging) status of our remaining battery capacity.
Boon docking more than a day or two without a battery monitor would leave us wondering how much longer before we run the batteries to 50%. Why wonder when, for $200, we can maintain an accurate knowledge of battery state? Best mod we've installed. See our article on it here.
12-08-2017, 06:56 AM
1985 31' Excella
st. Paul
, mn
I took a quick look at both company sites , the solar panel & the converter , just to have a little more info on what there are .
I would say 1st , I did not find a " expandable " label , and you had no mention of buying a kit [ charge controller etc. ] , just a 100 watt panel , and that is just a trickle charger - Ohms law saw just over 8 amps .
If you do want to get serous about solar , then designing a system [ vers. getting multiple popular products & mix & match ] .
Once you get more solar , above trickle charging , maybe a min. 20 -30 amp ++
Then putting more into a system , inverter - many of these have transfer switches - to go from shore power to battery automatically when the sense load against source , and then , again good ones will have programable charge controllers - to match your battery bank .
Then definitely have a solar system monitor , this is for many reasons , 1st off learning about your system , then watching for issues , weather maintenance or if you system is keeping up with your use .
As an example , not designing / building a SYSTME , will cause all kinds of failures / early replacement of components etc.
My last system allowed my to run 100% off grid and run AC , large color TV , microwave , large Bose stero system +++ , never got discharged more than 40% and the batteries lasted 14 yrs. .
The tell of a good system is - how long the batteries last !
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
12-08-2017, 07:57 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Given that you are replacing a multi stage converter with a multi stage converter, there isn't much gain in the converter swap out process. The only gain would be if you could actually improved the charging. That only happens if you add a temperature sensor.
Adding a coulomb counting monitor lets you work out how much is or isn't in your battery. It gives you a much better idea of when to stop using power. Since *that* is the source of a lot of battery problems, it's worth doing if you have repeat "battery dead" issues.
12-08-2017, 09:47 AM
2008 19' Bambi
Carlsbad
We live at sea level in California, and have room to park our trailer at home. Leaving the trailer plugged in for storage. Having a smart charger does a better job of maintaining the batteries health. I did the Progressive Dynamics swap for that reason. I don't recall hooking up a battery temperature monitor or voltage sense at the battery when installing the PD charger. Those features increase accuracy, and decrease charging time. The Morningstar MPPT solar charger I installed does have those features. We have been doing mostly boondocking, thus a high quality solar charging system along with an accurate Trimetric battery monitor with shunt. We have 2 100w portable panels that can be oriented toward the sun. We typically awaken in the morning to 80% remaining battery capacity. The panels are set out and on a sunny day the batteries will be back to 100% by 11:00am. Overcast days take all day to bring them back to full. We have 2 12v Interstate batteries of unknown condition. (came with trailer).
Russ
12-08-2017, 01:22 PM
San Francisco
Much thanks, appreciate the feedback. Yeah, I've decided to make the switch.
