Old 05-06-2012, 12:31 PM   #1
monroe , Louisiana
Progressive Dynamics 4045 install help
Hi, im new to the forum, I recently purchased a 1964 ambassador, and i am restoring it, my deal is i am replacing the converter with the PD 4045 all in one. i have searched and found some useful info. if anyone can tell me directly how to install this i would be thankful.
1. Is the MAIN the cord that plugs into a land power source?
2. how do i figure out which set of wires on the Airstream is for what (AC, curb, rear, front, etc.)?
3. I have 4 (four) wires coming out of the rear.
im so confused i have no idea what kin d of help to ask for
sup3rsh0cker is offline   Reply With Quote
Old 05-06-2012, 04:35 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Instructions for the 4045 are really junk! It took me hours of planning the installation I did. Use the search function here in the blue menu bar above. Let me see if I can find my other info. The converter works well by the way. Install it where you can easily see the fuses.
Old 05-06-2012, 04:41 PM   #3
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
photo installed
Here it is from the outside.
The grey junction box is just that...a junction box.
Name:	4045 converter.jpg
ID:	157589   Click image for larger version
Name:	4045 diagram.jpg
Name:	4045 installation.jpg
Old 05-06-2012, 05:46 PM   #4
monroe , Louisiana
thank you, that was the pictures i have already saved on my iphone... i already found your threads and it was the only helpful thing i could find. i have a question, im new to this, but with the converter i can only run DC if im not plugged up to a AC supply?
Old 05-06-2012, 06:13 PM   #5
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Yes...if you have a battery. You need an "inverter" to get AC from a DC source.
A"converter" does AC to DC.
Old 05-06-2012, 06:16 PM   #6
monroe , Louisiana
are the black wires (12) going to be ground? i see that they run to a bar, then it breaks to 4 wires running into to junkctioin box. then the white ground from the converter is connected to a bar that has a few wires running to the junkction as well is that connected to the 4 black wires going to the 12 wire bar?, its a little confusing. but on the diagram i see, it running to a bar then to a ground bar.
