Has anyone purchased and installed the Progressive Dynamics 4045 all in one electrical service panel from Vintage Trailer Supply? I am not an electrician, and the instructions are less than user friendly when it comes to someone with little electrical experience. My trailer had no 12v service at all, so I have nothing to go off of.
Explanations would be very nice. Pics or illustrations would be helpful.
After much searching I decided on this small, all in one. Still waiting to hear of anyones experience with one and the tight space for installation wiring problems.
I got the 4045 and ready to install......this thing is a mess! The instructions for it are worse than poor. I hope it works after figuring this out. If you have installed one....does it need a grounding bus bar added? Are real instructions available anywhere?
Thanks for posting that chart. The only thing I see that is missing is where does the tow vehicle wires come into play? And the running lights, etc. My trailer running lights will not operate unless the battery is in line and connected.
1956safari....sorry for the long delay. The unbilical (7 pin connect) will bring the power to your running and brake lights. In that 7 wire bundle, the black charge line will be the one that goes to the battery...thru a resettable CB.
My question.. HELP. In the new system I am building up....I am planning on 10 guage wire for the battery POS and NEG connecting cables. Electrical expert....will that do?
Do I use 50 AMP fuses on both of these cables?
Thanks.
4045 instructions are junk. One spot says to hook the converter wire to the MAIN circuit breaker. Another says to attach power in to the MAIN and the Converter to a BRANCH. Even their diagrams show different component wiring. So I am leaning toward attaching the converter lead to the Branch CB....1st on left and the main power inlet to the 30 AMP CB...2nd on left. The rest to the remaining 15 AMP Breakers.
The tech help line at Progressive D. will not answer....did they move to India?
So, what will ignite when I hook up power?
I would have recommended a 30/20. Main (30) and air conditioner (20). Then twin 15s on the others. One 15 being the converter by itself so you can isolate it or turn it off if needed. Don't see the need for all of those 20 amp breakers.
Thanks Randy....I will get the twin 15's tomorrow. I got the 20's from a local dealer and he will swap 'em out. I would have called you on this, but I bought this from Vintage and did not want to wear out my welcome with you. I did buy my Iota for the 94 Sovereign from you....and expect no problems there.
