Old 03-15-2009, 09:07 PM   #1
soldiermedic's Avatar
Florissant , USA
Progressive Dynamics 4045 Converter
Has anyone purchased and installed the Progressive Dynamics 4045 all in one electrical service panel from Vintage Trailer Supply? I am not an electrician, and the instructions are less than user friendly when it comes to someone with little electrical experience. My trailer had no 12v service at all, so I have nothing to go off of.
Explanations would be very nice. Pics or illustrations would be helpful.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 04-08-2009, 08:30 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
4045
Steve,
Did you get this converter? Do you, or anyone else like it?
Old 04-08-2009, 11:23 AM   #3
Florissant , USA
I have it...not installed it...waiting for someone to post on it.
Steve
Old 04-08-2009, 03:48 PM   #4
CrzyCorpsman's Avatar
1975 31' Sovereign
Biloxi , Mississippi
I got one myself. Although you know the currently "condition" of my A/S I'll be sure to follow the thread, though.
Brian Schmock
'75 31ft Airstream Sovereign
Come check out my restoration progress:
https://crazycorpsman-silverbullet.blogspot.com/
CrzyCorpsman is offline   Reply With Quote
Old 05-09-2009, 10:34 AM   #5
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I got one on the way
After much searching I decided on this small, all in one. Still waiting to hear of anyones experience with one and the tight space for installation wiring problems.
Old 05-10-2009, 09:26 PM   #6
New Borockton , Alabama
Images: 21
Its probably the best small converter on the market except the Iota ILS needs loved too because they just don't fail. They both do a great job.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 05-24-2009, 02:48 PM   #7
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Where to begin?
I got the 4045 and ready to install......this thing is a mess! The instructions for it are worse than poor. I hope it works after figuring this out. If you have installed one....does it need a grounding bus bar added? Are real instructions available anywhere?
Old 06-24-2009, 03:18 PM   #8
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
rough out on my installation
I did have to buy a grounding bus because I ran grounds from all 12v fixtures. Got it from Best Converter.
Name:	4045 diagram.jpg
Old 06-25-2009, 07:51 AM   #9
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Thanks for posting that chart. The only thing I see that is missing is where does the tow vehicle wires come into play? And the running lights, etc. My trailer running lights will not operate unless the battery is in line and connected.
1956Safari is offline   Reply With Quote
Old 09-13-2009, 10:06 AM   #10
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
ELECTRICAL....back at it....need help again
1956safari....sorry for the long delay. The unbilical (7 pin connect) will bring the power to your running and brake lights. In that 7 wire bundle, the black charge line will be the one that goes to the battery...thru a resettable CB.
My question.. HELP. In the new system I am building up....I am planning on 10 guage wire for the battery POS and NEG connecting cables. Electrical expert....will that do?
Do I use 50 AMP fuses on both of these cables?
Thanks.
Old 12-10-2009, 09:02 PM   #11
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Power input??
4045 instructions are junk. One spot says to hook the converter wire to the MAIN circuit breaker. Another says to attach power in to the MAIN and the Converter to a BRANCH. Even their diagrams show different component wiring. So I am leaning toward attaching the converter lead to the Branch CB....1st on left and the main power inlet to the 30 AMP CB...2nd on left. The rest to the remaining 15 AMP Breakers.
The tech help line at Progressive D. will not answer....did they move to India?
So, what will ignite when I hook up power?
Name:	4045 converter.jpg
Old 12-13-2009, 07:13 PM   #12
Images: 21
I would have recommended a 30/20. Main (30) and air conditioner (20). Then twin 15s on the others. One 15 being the converter by itself so you can isolate it or turn it off if needed. Don't see the need for all of those 20 amp breakers.
888-828-1893
Bestconverter.com
Old 12-13-2009, 08:53 PM   #13
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Change is coming up
Thanks Randy....I will get the twin 15's tomorrow. I got the 20's from a local dealer and he will swap 'em out. I would have called you on this, but I bought this from Vintage and did not want to wear out my welcome with you. I did buy my Iota for the 94 Sovereign from you....and expect no problems there.
Old 12-13-2009, 09:58 PM   #14
Images: 21
No worries, you know you are just a personal call away if you have any issues with your converter. We have them figured out.
888-828-1893
Bestconverter.com
Old 01-04-2010, 01:57 PM   #15
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
It's in....and works.
The 4045 is finally installed. The 12 volt system works great. As part of my learning experience with electrics....the 115v could not be tested because the Marinco inlet and cord I installed have three curved blade, 30 AMP, plug....not like the 30 AMP three prong (one round) plugs I have on other things. Awaiting the adapter now.
Name:	4045 installation.jpg
Old 07-12-2011, 03:10 PM   #16
Saint-Augustin , Quebec
How is the cooling fan?
Noisy?
I am thinking of getting this panel.
Thanks in advance
François
Fpoet is offline   Reply With Quote
Old 07-12-2011, 04:43 PM   #17
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
fan
Hi...I cannot hear the fan noise at all. It seems like a great small panel.
Old 07-12-2011, 11:22 PM   #18
adobehome's Avatar
1962 19' Globetrotter
New River , Arizona
very quiet
I also have installed the 4045 & love it! Yes, instructions suck & make little sense, at least not to us electrical neophytes. But, Randy is very helpful, although tech support at Progressive Dyn. is not, so much. I cannot hear one little peep from this converter. That fan does not run continuously, I don't think, because I can never hear it when and if it goes on. It has been plugged in to 110 house power continuously, for over a month as I've been working on the GT, in temperatures here in southern Arizona ranging from 100-118.
Judy
'62 GT
adobehome is offline   Reply With Quote
Old 07-15-2011, 06:10 AM   #19
Ok, thank you both for your replies. I have ordered the unit and will install it next week, hopefully.
Cheers!
François
charger, converter, progressive dynamics
What to do with old converter? msmst25 Batteries, Univolts, Converters & Inverters 11 06-15-2008 03:32 PM
Where's the converter? gparker Batteries, Univolts, Converters & Inverters 4 08-24-2007 03:30 AM
New Progressive Dynamics convertor, AGM battery, and Pendant questions wacnstac Batteries, Univolts, Converters & Inverters 16 05-09-2007 09:12 PM
Need Some Help - converter jjohnjr Interior Restoration Forum 0 08-23-2006 06:21 PM
EMS from Progressive Industries markjoandall Electrical - Systems, Generators, Batteries & Solar 0 08-02-2005 07:14 AM
