Old 03-18-2013, 08:30 AM   #1
SteveH's Avatar
Common Sense , Texas
PowerMax PM4B-60 Converter
I've been wanting to upgrade my battery boiler OE converter to a better quality three stage converter.
Anyone have any experience with the above mentioned converter, and have a review on it, or any other PowerMax converter?
Thanks in advance for your input.
Regards,
Steve
Old 03-18-2013, 08:47 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I have the PowerMax Boondocker 45-amp converter in my Argosy. I can say that it's a VAST improvement over the WFCO converter it replaced. The voltage is stable and the converter seems to put out a decent amount of current before the fan cycles on, whereas the WFCO had enough periodic variation in the output voltage that you could see it in the lights brightening and dimming several times a minute, and turning on a light or two would set off the cooling fan on the converter even in cool weather.
So far I'm happy with the purchase.
David
Old 03-18-2013, 10:07 AM   #3
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
I also just recently (about 3 weeks) put in the Boondocker 45. Like the above post it is working just fine so far. Not a bad price and 3 year guarantee not to mention about 30 lbs lighter than the solid iron block I removed. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-18-2013, 10:48 AM   #4
1974 Argosy 20
Kooskia , Idaho
I have had very good experience with the Progressive Dynamics PD9245. It is a 3 stage 45 amp charger and is inexpensive, in the range of $140 to $200 depending on where you buy it. I have changed out 4 different RV's with the PD and each has worked faultlessly.
Old 03-18-2013, 12:16 PM   #5
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
I have a 60 amp 3 stage Powermax Boondocker in my trailer that I installed last year. So far it has worked well. I bought it from Randy and Best Converters.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 03-21-2013, 03:11 AM   #6
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
A couple of threads below, you can see where I just installed the 60-amp 4-stage. Only a single night's stay in it so far, but the instant piece of mind alone is almost worth the price. As I get more and more experience and gain more observations, I'll keep you updated, if you'd like.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 03-21-2013, 05:18 AM   #7
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
No issues with the 55 amp I installed 2 months ago (I fulltime). I've only heard it twice in all that period after the initial switch on.
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
