Old 09-02-2011, 03:55 PM   #1
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Powermax converter with Parallax fuse block
I would like to install my new converter and fuseblock over the weekend. I'm looking at the directions that came with the converter and it looks straightforword enough. Only thing I'm not sure of is what to do with the 50amp fuse block that the battery neg. wire goes into on my old setup. Does that fuseblock get eliminated and I now go straight into the new converter?
Also on the Parallax fuseblock. I see where the 12VDC neg. wire goes into the fuseblock but on the positive side there are 3 lugs across the top. Which one should I connect to?
Thanks for the help.
Flynavy is offline   Reply With Quote
Old 09-02-2011, 07:05 PM   #2
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
Here's what I did with mine, that way I got to keep the ammeter on the panel working. The 50 amp fuse is at the top of the box, and you can attach the pos to any of the three lugs.....Phil
pgr32e is offline   Reply With Quote
Old 09-02-2011, 08:58 PM   #3
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
That looks pretty neat Phil. Did you remove the fuse panel from the univolt and reuse it?
My ammeter has never worked to begin with.
Does the 50amp fuse protect the fuse panel?
Old 09-02-2011, 10:17 PM   #4
New Borockton , Alabama
Images: 21
Hi Flynavy,
I would leave that 50 amp fuse inline. Its not hurting anything and protects the wire between the batteries and the fuse panel.
The three postitive lugs at the top of your new fuse board are all the same. Just pick one to use from the converter and another to your battery. The left side bar is negative. Good luck.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 09-03-2011, 03:44 AM   #5
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
I put breakers on the pos and the neg. I have no idea why. I thought.. what can it hurt?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Converter connundrum: fuse panel options? Phrunes Batteries, Univolts, Converters & Inverters 0 08-17-2011 07:53 PM
Converter Conundrum benyeomans Batteries, Univolts, Converters & Inverters 15 07-29-2011 02:56 PM
Intellipower Converter wlanford Batteries, Univolts, Converters & Inverters 24 07-21-2011 10:27 PM
Converter Question henw Batteries, Univolts, Converters & Inverters 5 05-10-2011 06:55 AM
