Old 10-16-2015, 04:45 PM   #1
Dallas , Texas
Power to Load Center but nowhere else?
I bought a 2000 AS and power worked fine at the former owner's house but when I got it home I got power at the 50 amp load center but no where else, i.e., plugs, lights, slideouts, etc. It has a 50 AMP load center, all breakers test ok, I get 120 current at every breaker but why is it not getting to all of the rest of the electrical devices. I have looked everywhere for some major off/on switch but found none. It does have an inverter/converter and I wonder if that needs to be tested?
gofigbruce is offline   Reply With Quote
Old 10-16-2015, 05:10 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Are breakers turned on?
Old 10-16-2015, 06:09 PM   #3
1974 Argosy 20
Kooskia , Idaho
Are you measuring the power between the hot line and the ground rather than the hot line and the neutral? If so, it would look like there is power at the breakers, but if the neutral was open it would not get to the circuits. Check that you are actually measuring between the breaker and the neutral bar, not the ground bar.
Look for an open neutral line.
No brakes, but everything else works... what's wrong? groshko Brakes & Brake Controllers 5 08-07-2010 05:51 PM
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 07:36 AM
Help and advise she died in the middle of nowhere saxonsraven Airstream Motorhome Forums 7 07-29-2003 07:10 AM
Wires to nowhere Craig Electrical - Systems, Generators, Batteries & Solar 3 10-01-2002 07:03 PM
