Originally Posted by millvalleyca
Hi
Is it ok for me to use my trailer battery to power an air compressor to fill my tires or is it better to use the battery in my truck?
Thanks guys....you've been great answering my quetions!
Either will work well and I have used both with my 12VDC compressor. The only thing to consider is the recharge rate of the battery and how it will be re-charged. If you're on the road, I would consider using the TV battery since it will be recharged fasterwhile your motor is on. If parked at a camp ground and plugged in to 120VAC, the trailer battery will be re-charged by your converter.
If you have a short power supply cord (nothing personal here), then which ever battery is closest .
lewster
