If turning the breaker from on to off and then back on restores power then the breaker is tripping. Are you talking about a breaker inside the trailer or a breaker on the power outlet for the campsite? If it is the campsite then you need to talk to the campsite people and get it fixed. Weakened breaker or a wiring problem.
If it is in the trailer it is possible you have a breaker with a weak trip. If you trip a breaker a lot it can wear it out. I guess it is also possible you have an intermittent short. I would try a very low load like a light for a while and see if the breaker trips. The heater and the coffee pot make pretty heavy loads. You should have more than one circuit in the trailer. Can you plug the heater or the coffee pot into a outlet on a different circuit (breaker) in the trailer? And be sure not to have a heater and a coffee pot going at the same time. Your trailer circuits will probably only handle one load per circuit at a time.
Is the breaker that is tripping a ground fault breaker?
Is your
12 volt power working? About the only thing that a storm could fry would be the converter and probably not even that.
Where in Montana are you? Nothing to do with the problem. Just curious. (I can not imagine surviving a winter in an Airstream in the parts of Montana I have visited in the winter}
