Old 06-19-2010, 12:12 AM   #1
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
"Power On" light not working
I recently had my old univolt replaced with a modern converter that won't fry my batteries. Before replacing the univolt, the red "power on" light on the control panel worked. Now the light does not work but the converter is working fine. I checked the wiring from the 12V panel to the converter and there is a brown wire coming out of the 4 amp "power on" fuse that is taped off and dangling near the converter. It is too short to reach it. I'm hoping this wire connects to something and the light will work again. Any ideas?
4RXLA is offline   Reply With Quote
Old 06-19-2010, 08:30 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
First assumption from the fact you see that wire coming out of the 12 volt panel would be that the Power On Light was 12 volts. Not sure that makes sense since the light would be on any time the battery was present unless there was a separate 12 volt tap on the univolt that was isolated from the battery.
If that was the case you could install a 120 relay on the input side of the converter and use it to switch the 12 volt power to the Power On Light. This would cause the Power On Light to only be on when you had shore power.
A simple 120 volt voltmeter plugged into one of the receptacles would indicate shore power and also monitor the voltage coming in from the campground. If you have an AC that is a much greater condition to monitor. Low voltage, below 105 volts ac, will kill an AC fast
2004 Excursion 4x4
Old 06-19-2010, 09:52 AM   #3
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
The Univolt had an output for the power on light and a shunt for the ampmeter if you have the old Univolt you can take the fuse block off and use it for the power on and ampmeter.
Here is how it is done
Univolt replacement
Garry
Old 06-19-2010, 09:59 AM   #4
Univolt replacement
There is a simple wiring change that's made at the monitor panel, that makes the "power on" light work correctly when the coach is plugged into city power, when a new style "Univolt" is installed.
I will post it later, when I am back in my office.
Old 06-19-2010, 02:35 PM   #5
Power "ON" light
UNDERSTANDING THE POWER ON LIGHT
1. The power on light IS NOT WIRED to positive voltage on one side ans negative on the other.
A. Checking the wires to the light with the trailer unplugged will show positive battery voltage on both wires. Since the voltage is the same on both sides of the bulb there is no current flow through the filament and it does not glow.
1. The positive battery voltage on one side comes direct from the battery. The positive battery voltage on the other side comes from the battery, through the univolt, and out the power on light circuit to the bulb.
2. The power on light is wired with one side to the positive battery voltage,and the other side to the power on light circuit of the univolt.
A. Checking the wires to the light with the trailer plugged in will show univolt/battery DC voltage on one side and univolt unrectified AC voltage on the other. The reading will practically be the same except one is DC and the other is AC. Example: 12.6 plus DC one side versus 12.6 AC on the other side. Since there is a voltage potential difference between the wires there is a current flow through the filament and the bulb will glow.
1. The positive DC battery current on one side comes direct from the battery. The AC current on the other side comes from the transformer windings in the univolt before the current is rectified.
Now that everyone has that information, it becomes a problem when a new style converter is installed. The following will tell you how to modify the circuitry to make the power on light work again.
A converter with a new name has been used in Airstream trailers and motorhomes, since the end of February 1988. The name is MAGNETEK, and it replaces the Triad/Utrad that was used for many years. The basic design is the same.
All functions and testing remain the same, except for the power on light circuit. In past years, the wiring on the power on light was positive on both sides (read above), and only the difference in voltage potential, AC versus DC, caused the light to function.
On the current Magnetek converters the power on circuit provides 12 volt DC to one side of the bulb and the other side is ground. This 12 volt power is picked up from the 18 gauge wire from the converter.
When a Magnetek is used to replace a Triad/Utrad, the wiring must be changed at the power on light in the control panel. The purple wire to the power on bulb will not have to be changed. The "black" wire WILL have to cut and spliced into one of the white ground wires.
And finally, you can have another swig, make it a long one, of your cool one.
Hopes this squares away the problem.
Old 06-19-2010, 03:32 PM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
just made my own power on indicator by using a 12v cube transformer (think cell phone charger etc.) and connected it to the "ac power on" wire in my coach. one side to the black wire the other to negative.
plugged it in right next to the intella power cord and my light is working as before.
note, mine uses a led on the control panel and they are polarity sensitive, just swapped it around until the led lit.
simple.
john
you call them ferrets, i call them weasels.
Old 06-20-2010, 10:42 AM   #7
power on light.
Any comments?
Old 06-21-2010, 01:16 AM   #8
4RXLA's Avatar
Images: 33
Thanks Andy for the info. The light is working once again!
Old 06-22-2010, 11:08 PM   #9
New Borockton , Alabama
Images: 21
You can also use somethining that runs on AC plugged into an AC outlet like the microwave clock if installed, alarm clock, cell phone charger, etc that has an LED with it. There is also the Bill Worden wall wart way that John posted above. I have not done it because I have a small clock that tells me when I have AC but it sure would be simple.
http://www.bestconverter.com/assets/...t/Univoltp.pdf
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
Old 06-17-2012, 05:06 AM   #10
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
1. The power on light IS NOT WIRED to positive voltage on one side ans negative on the other....................
Reviving this old thread to get some input on the intelli charger and the power on light. It does not have its designated 12V current to feed that panel light. Any suggestions for a work around, since coach Battery current is always present, you can not use the 12v charge current of the intelli charger for the power on light
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 06-17-2012, 06:02 AM   #11
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Variation on a theme
OK Andy how about this,
I have a 1991 Excella. At some point in history the PO replaced the assumed Univolt charger with an IOTA converter. My "AC power LED does not light, nor do any of the fluid (fresh, grey, black) indicators on my monitor system work. HOWEVER, both LPG, and battery LEDs function normally.
Is there a correlation between the AC indicator (system) not working and my tank sensors not working, or is this just wishful thinking?
Stumped by this...
Old 06-17-2012, 07:03 AM   #12
Stumped by this...
There is an answer to correct that issue, but it's at my office.
I will post the answer later today or tomorrow.
Old 06-17-2012, 09:49 AM   #13
Post # 5 above, explains the power on light "how to" fix.
Old 06-17-2012, 10:10 AM   #14
Airstream Driver
1997 30' Excella
Images: 51
Yes, Andy , post #5 above explains the wiring issues with the old converters and how to fix it with the new Magnetek converters with a designated 18 gauge wire for the indicator light. Intelli Charger do not have the designated wire and have 12v volt power going to the + terminals at all times from the house batteries.
My questions was if there is a way to make it work under those circumstances.
1996 Airstream B190
AIR #13
Classifieds "Contact Seller" Link Not Working Joe Z Forum Admin, News and Member Account Info 10 05-14-2008 07:32 AM
Power problem indicated by "weak" microwave? davida Batteries, Univolts, Converters & Inverters 4 06-12-2007 01:23 PM
How are the "Cheap or Free" posts working out? Bob Thompson Boondocking 2 10-29-2006 11:36 AM
Power steering problem on my "NEW" 345 JBK Mechanics Corner - Engines, Transmission & More... 19 10-23-2006 08:54 AM
