Old 07-25-2012, 06:31 PM   #1
Powerlineman's Avatar
1974 31' Excella 500
Wellston , Jackson
Power converter problems.
Hey everyone let's start off by saying thanks to everyone that has been reading my post and giving me lots of information. It has all been such great help.
But now I'm starting with a new problem. I have good 110 power but can't get no 12 v. The converter is making a humming noise for a little less that 2 sec. Then clicking off. And it does this repeatedly until unplugged. So my question is , is my power converter bad?
Powerlineman is offline   Reply With Quote
Old 07-25-2012, 06:40 PM   #2
Wellston , Jackson
Also all the fuses test good from top to bottom but the power is not making it to the tester up front of the nose.
Old 07-25-2012, 07:28 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It sounds like your converter is "crow baring" which means it is shutting itself down automatically because the output is overloaded.
Is this one of the modern converters?
Are you just installing it?
The first thing I would do is. Shut it off. Disconnect the two DC wires. The turn the converter back on. If it still cycles the problem is internal.
If it stops cycling. Make absolutely sure you have the wires on the output connected with the right polarity. Both at the battery(s) and at the converter. If it was wired backwards there may be fuses blown on the converter.
If this does not solve the problem. Remove all of the fuses from the fuse block. Then reinstall them one at a time starting with the largest. Probably 50 amp. Until the converter starts to crow bar. When it does, you have located the problem.
TG Twinkie is online now   Reply With Quote
Old 07-25-2012, 07:52 PM   #4
Wellston , Jackson
Man I am so glad this forum is around hahaha. I will try that first thing tomorrow and see what happens. I believe that converter is the original one.
Old 07-25-2012, 08:03 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If it is original, I see a new converter in your future...
Richard
Old 07-25-2012, 08:21 PM   #6
Wellston , Jackson
If so what converter do you recommend.
Old 07-25-2012, 08:42 PM   #7
2002 25' Safari
Dewey , Arizona
Images: 62
I put in a Intelipower PD-9245 in my trailer and it has worked very well for the past several years. There are other good units available as well.
Richard
Old 07-25-2012, 10:09 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Did the same as Azflycaster. It has worked flawlessly for over 2 years. You can find the converter on eBay.
If your converter is about the size of a cinder block but heavier it is the original.
Old 07-26-2012, 06:41 AM   #9
Wellston , Jackson
Does that one charge the battery also?
Old 07-26-2012, 06:46 AM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Yes. The Progressive Dynamics 9245 charges the batteries. Do you know what is in the trailer now?
Have you made any recent changes to the system?
Old 07-26-2012, 08:28 AM   #11
Kevin245's Avatar
We use Progressive Dynamics Inteli-Power products. We have one in our Avion that performs flawlessly and we recently replaced the univolt in our 76 with their PD9260. It was a simple process taking less than 15 minutes.
Eleanor Roosevelt
Old 07-26-2012, 06:59 PM   #12
Wellston , Jackson
Well I ordered the 9246 C. Is this the right one?
Old 07-26-2012, 07:00 PM   #13
Wellston , Jackson
I mean the 9260 C. Sorry
Old 07-26-2012, 07:25 PM   #14
Wellston , Jackson
And also I took all the fuses out and it still clicked and carried on. So my guess is that it was bad.
