Old 07-26-2012, 09:34 PM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The 9260 will work just fine.
Old 07-27-2012, 02:12 AM   #16
Powerlineman's Avatar
1974 31' Excella 500
Wellston , Jackson
Thanks again everyone. Very much appreciated.
Powerlineman is offline   Reply With Quote
Old 07-31-2012, 06:44 PM   #17
Wellston , Jackson
How Does this wire up to that.
Old 07-31-2012, 07:10 PM   #18
Wellston , Jackson
Does this mean I bead a fuse board.
Old 07-31-2012, 07:10 PM   #19
Wellston , Jackson
Need a fuse board. Sorry.
Old 07-31-2012, 07:43 PM   #20
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you are going to use the old fuse panel with the new converter. First tell us where the large red and black wires on the fuse panel go?
The converter should be wired in such a manner that it is connected to the fuse panel where the large red (positive) and black (negative) and to the battery positive and negative terminals respectively.
There should be fuses 30 to 50 amps between the battery and the fuse panel. The converter has its own internal protection rated for the particular converter. You must make sure that the wires connected to the converter are large enough to handle the current capability of said converter.
Old 07-31-2012, 07:46 PM   #21
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Meant to say we need the ID of the large white wire as well. My guess is that it goes to the chassis of the trailer.
Old 08-02-2012, 04:52 PM   #22
Wellston , Jackson
Wahooooo it's in and working. Thanks again everyone for your help. Another successful task done. Everything is so much appreciated.
Old 08-06-2012, 04:59 PM   #23
1984 31' Sovereign
1978 Argosy 24
Zavalla , Texas
The PD9260 in my Airstream works great .... I did get word from one AS Technical Guy that the PD does not like AGMs as well as some of the others like Powermax. However, I have AGMs in both trailers and have no issues.
Orlop is offline   Reply With Quote
Old 08-06-2012, 05:33 PM   #24
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have had the same setup for over 5 years with no issues. In fact the charging profile for my PD9245 is the same as the Lifeline AGM that I have installed
Richard
