Old 05-08-2010, 08:07 PM   #1
1973 23' Safari
Encino , California
Power Converter & Power Supply
I just got my first Airstream yesterday. It's a 1973 23' Safari. I am asking for advice on what is a good Power Converter & Power Supply.
Land Shark is offline   Reply With Quote
Old 05-09-2010, 01:39 AM   #2
Airstream's currect Univolt, that has been used for some time, works well.
Old 05-09-2010, 02:07 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I installed this in my trailer: Intelli-Power PD9245C 45A Electronic RV Converter/Charger
Richard
azflycaster is online now   Reply With Quote
Old 05-09-2010, 02:29 PM   #4
New Borockton , Alabama
Images: 21
If you plan to charge a battery, one of the multi stage charging units like the Iota or PD would be best.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 05-09-2010, 09:56 PM   #5
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Landshark
I also installed a 45 amp converter (9200 series) from Intellepower (PD) and am very pleased with this product. I purchased this from Best Converters.
Welcome to the Forum.
TouringDan
Old 05-09-2010, 10:14 PM   #6
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
progressive dynamics all in one unit without good instructions
I picked up one of these: Progressive Dynamics 4045: 45 Amp Converter + AC/DC Distribution Panel but will have to seek out an electrician as the "instructions" have absolutely no step by step instructions. This was very disappointing because i was hoping to learn alot along the way and do it myself--perhaps that's their way of not getting into legal trouble by offering advice to novices. i just thought i'd throw that info out if you're considering the product. Also, i just figured out that the cutout for the breakers is off by a quarter inch--so you can't fill as many circuits as they advertise. I purchased the breakers they recommend as well. so far i'm unimpresed but i hear it's a good product--we'll see. cheers--ted
the544man is offline   Reply With Quote
Old 05-10-2010, 08:17 AM   #7
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
I replaced only the univolt and not the 12 distribution panel because the panel was fine, only the univolt was shot. Replacement of the univolt with the PD 45 amp converter is very straight forward. You connect up the 12 volt wires (positive, negative and ground the unit) and plug the converter into an outlet ( I installed a new receptacle because the old univolt was hardwired in). The new converter is about 1/4 the weight and size of the old univolt.
Old 05-10-2010, 11:46 AM   #8
Ag&Au's Avatar
Port Orchard , Washington
Replacing my Stock Converter
After pricing the LifeLine glass mat batteries that came with my boondocker package, I have decided that replacing the Parallax 7455 that came with the trailer will be cost effective (even though it is less than a year old) over the long run. Following the advice of Randy at WWW.BestConverter.com, I have ordered the Iota DLS-55 with IQ4 smart controller. I am hoping to mitigate the expense, by using the 7455 as a power supply for some of my ham radio stuff, if it turns out to have clean enough output.
Regards,
Ken
Old 05-11-2010, 09:51 AM   #9
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
regarding my comments above on the Progressive Dynamics Coverter above: After talking to an electrician--i was able to dicipher the progressive dynamics all in one converter diagram. they do give a diagram--just not an exhaustive orderly "step by step instruction manual". and the cover does fit fine--i made a mistake on that. i just wanted to clarify my comments above. sounds like you are getting good advice here. cheers--ted
New Power Converter 66 Tradewind Batteries, Univolts, Converters & Inverters 10 07-06-2015 02:04 PM
new power supply now tripping GFI housebg Batteries, Univolts, Converters & Inverters 32 04-16-2009 01:15 PM
UPS back-up power supply in an AS? richinny Batteries, Univolts, Converters & Inverters 8 09-30-2008 01:17 PM
Power supply ? starflyte1 Batteries, Univolts, Converters & Inverters 4 03-19-2007 08:29 AM
Power Jack electric supply GREGLC53 Electrical - Systems, Generators, Batteries & Solar 10 12-31-2006 03:35 PM
