Old 05-17-2005, 06:23 PM   #1
Power Converter?
I suspect this is a common issue. When the airstream is pluged into 110 volt, it drains the battery. It just started as I was preparing it for a trip this weekend. What do I need to replace?
Maediris73 is offline   Reply With Quote
Old 05-17-2005, 08:14 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi, Have you checked the converter? If you are plugged in to 110v you will still power everything but you may not be charging the battery. I replaced my converter from this place www.bestconverter.com. It's the best price I found. Good Luck Lee
silverleeper is offline   Reply With Quote
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 06:52 AM
power boosters John Our Community 18 11-19-2002 03:54 PM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 08:45 AM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Converter box for into floor mount FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-15-2002 09:49 PM
