Old 01-15-2008, 04:37 PM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Power consumption of various 12 volt items
When I installed my Trimetric 2020 which allows one to measure how many amps are being withdrawn from the batteries I used it to measure the power consumption of most of the 12 volt items in our 1984 310 Limited MH.
I thought this information might be useful for others so I'm posting it here.
Amps ...... Item
0.5 ........ Everything off - I assume this is the draw from the detectors (LP and CO) and the logic boards in the appliances
0.2 ........ 400 Watt inverter with no loads on it
12.0 ....... Main cabin lights on high consisting of (12) 1141 incandescent bulbs
6.5 ........ Main Cabin lights on low consisting of (12) little bulbs - don't know the number of the bulb
1.0 ........ Individual 'eyeball' lights in main cabin - there are a total of 4 of these with individual switches
6.8 ........ Kitchen lights on high
3.2 ........ Kitchen lights on low
2.6 ........ Kitchen exhaust fan
2.1 ........ Fantastic fan on high
1.6 ........ Fantastic fan on medium
1.1 ........ Fantastic fan on low
1.7 ........ Shower fan
1.5 ........ Bathroom fan
0.1 ........ Water pump Idle
2.7 ........ Bathroom ceiling light
1.4 ........ Shower light
1.4 ........ Medicine cabinet low - fluorescent light
4.7 ........ Medicine cabinet track lights
3.9 ........ Bedroom dual fluorescent
1.4 ........ Bedroom Individual reading light
0.2 ........ 15 inch LCD TV plugged in to 12 volts but turned off
2.8 ........ 15 inch LCD TV powered directly from 12 volts turned on
3.8 ........ 15 inch LCD TV powered by the 'brick' that came with it plugged into 400 watt inverter
2.6 ........ Satellite PVR plugged in to converter
0.5 ........ Toshiba laptop plugged in to inverter but with computer off
2.5 ........ Toshiba laptop plugged in to inverter but with computer on
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 01-15-2008, 04:51 PM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
That's interesting stuff, Guy. Thanks for the post
Pat
pmclemore is offline   Reply With Quote
Old 01-16-2008, 08:05 AM   #3
guy99's Avatar
Images: 16
5.0 amps - furnace and blower
Old 01-16-2008, 08:11 AM   #4
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Thanks Guy!
how about the oven light?
See you in April
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 01-16-2008, 08:39 AM   #5
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Good post, good info.
Fyrzowt is offline   Reply With Quote
Old 01-16-2008, 08:55 AM   #6
guy99's Avatar
Images: 16
Originally Posted by doorgunner
Thanks Guy!
See you in April
Oven light? What's that? Maybe I don't have one.
Old 01-16-2008, 09:16 AM   #7
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
That's what I suspected. On our way to the Can Opener, we overnighted at a truck stop. It went down into the 20s that night and we ran the furnace (set at 50 degrees) and the tank heaters all night to keep us warm and thawed out. By morning we had an amber warning on the battery monitor, and after we cleaned up it was in the red and flashing if we turned anything on. In the three hours we drove from there to the Can Opener, the truck had charged it up to full again.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 01-16-2008, 09:22 AM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
Tank heaters? Aren't those supposed to be 120V? Do you have an inverter? I've boondocked nights down into the mid-teens with just furnace alone and had plenty of battery. I do think conditions that cold are too much for the furnace to keep up with while underway -- so I drain all 3 tanks if I have to pull in the cold and set the furnace at about 50. I set it at 65 once and used 25# of LP in 300 miles!
Excellent report Guy!
5 meter Langford Nahanni
Old 01-16-2008, 10:17 AM   #9
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
The tank heaters I plan to use are 12v (actually 13.5v). They are also available in 120v.
The model 1200 which is good for up to 40gal tanks is rated at 9.9amps.
Bob... you are braver than me. We don't plan to do much winter camping and if we do it won't be boondocking. I am installing the heaters as a precaution... just in case we get some of that unpredictable upper-Midwestern weather.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 01-16-2008, 10:22 AM   #10
Steve -- winter? It was mid-October 2006 while driving to Madison for a wedding! Guess I should have said 350 miles...
To the sunny-staters -- we have seen subfreezing temps even in September. August 30, 1974, dawned to about 16 degree temps and was the worst in my memory.
Guy, I don't know if your fridge is a 2-way or 3-way. Do you know what current is used when running on LP? Thanks again -- karma your way!
Old 01-16-2008, 10:33 AM   #11
1967 28' Ambassador
1970 29' Ambassador
Exactly! This is why we need the heaters. LOL! BTW they are thermostatically controlled so they only heat when the heat is needed.
Guy,
Thanks for the interesting info. Your post will serve as a great reference.
Steve & the crew
Old 01-16-2008, 11:34 AM   #12
guy99's Avatar
Images: 16
Mine is two way. I think the power it uses while on LP is included in the .5 amp base load. Sometime that base load will go up to .7 or .8 for no reason I can detect. Maybe the fridge is up to something?
I wonder how much those 12 volt tank heaters actually run. They would sure would consume battery capacity if they were on much. Might be handy for when you are underway and have power from the tow vehicle?
Old 01-16-2008, 11:58 AM   #13
_
... In the three hours we drove from there to the Can Opener, the truck had charged it up to full again...
sorry but this is not likely.
IF the coach battery/s is depleted much, 3 hours of driving isn't gonna recharge them.
depending an alternator and wire size (output) 30-50 hours of driving without usage is needed to bring them up to 80% or more...
the confusing thing is your monitor 'shows' fully recharged which IS confusing...
that's is only a surface reading of voltage; once the electrolyte as homogenized charge across the plates/gel/fluid a lower reading will appear.
this is sort of like judging the temperature of a full body of water by touching the surface...
seems warm (fully charged) but go deeper or stir it up and the true temp is much different.
after the 3 hours of driving and the apparent 'full charge' had you boondocked, the voltage would have dropped way down really fast...
again this is confusing but that sudden drop is a reflection of how little juice had actually been replaced.
cheers
2air'
good list guy'! thanks.
with the various models of lights, fridges, and appliances in use it's important to keep differences in mind while using this reference.
Old 01-16-2008, 01:15 PM   #14
depending an alternator and wire size (output) 30-50 hours of driving without usage is needed to bring them up to 80% or more......
.....after the 3 hours of driving and the apparent 'full charge' had you boondocked, the voltage would have dropped way down really fast...
again this is confusing but that sudden drop is a reflection of how little juice had actually been replaced....
I noticed this issue earlier but didn't have time to post. I'm in full agreement here. Most TV's alternators have little reserve output beyond what it takes to run the TV's systems, air conditioner, etc. Less of that small margin of amperage makes it to your converter and battery due to the length of the wiring run. What about amps to run a resistance tank heater? Ulp!
I've read (and sadly repeated ) figures here at AIR about a minimum of 200 miles to recharge the coach batteries. I've since heard from better sources that this isn't close to enough. 30-50 hours? Ya picks yer poison. But at Topsail you probably had a 30A power pillar to plug into, right? Let me hear ya say, "Ahhhh!"
My truck has an optional snowplow package with an extra output HD alternator and 2 batteries -- I'm won't even bank on that recharging much while I drive. The lightweight Honda genset comes with me everywhere I don't have a hookup.
12 volt
No 12-Volt Power Silver Threads Batteries, Univolts, Converters & Inverters 28 07-03-2007 08:53 PM
Consumption Estimates campadk Electrical - Systems, Generators, Batteries & Solar 8 02-03-2007 09:54 AM
Poll: FUEL CONSUMPTION brunoffrance On The Road... 32 02-29-2004 04:37 PM
LP consumption by the furnace? ipso_facto Furnaces, Heaters, Fireplaces & Air Conditioning 18 12-10-2003 10:43 AM
Fuel Consumption: (curious) Drew Tow Vehicles 15 12-26-2002 06:28 PM
