Old 01-16-2008, 08:01 PM   #15
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Okay, stop beating up the new guy
I only reported what my monitor panel showed (full charge) but what 2air says makes sense. That probably was the condition of the batteries, but we plugged into a power post at Topsail and didn't worry about it anymore.
I have read that deep cycling your batteries periodically is better than leaving them on a trickle charge all the time. So I guess that counts for a deep cycle.
Tank Heaters. On the side of my bathroom wall are two switches that turn on the tank heaters. One for Black and one for Gray/Fresh. I was shown these at delivery and the tech explained that these should be on when the temps are freezing (driving or parked). They light up when not plugged in, so I assumed they ran off the 12v system. Is this not correct?
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 01-16-2008, 08:12 PM   #16
CanoeStream's Avatar
St. Cloud , Minnesota
You shouldn't discharge a lead-acid below 50% -- that will affect it's life & capacity.
OEM tank heaters? I thought they were 110V -- maybe got that from NeatAirstream in a post? For sure they won't do much off of batteries if they are 12V! Talk to your dealer?
5 meter Langford Nahanni
Old 01-16-2008, 08:50 PM   #17
Viera , Florida
I was recalling an Article I read in Airstream Life (Fall/Winter 2006). I looked it up, and stand corrected. Here's what it says:
If a new deep cycle battery is routinely discharged to 10% or less remaining and then properly recharged (i.e. initially a high current bulk charge, followed by lower topping-off-current-charge), it will have an average life of about 300 - 350 cycles. This amounts to a few years of typical useage in most Airstreams.
On the other hand, if that same battery is routinely discharged to around 40% to 50% remaining and then recharged, that battery will have a life span of around 3,000 cycles.
My question now is: If the monitor was showing red in steady state and flashing red when something was on, what was the battery level? Especially since we now know that an indication of full charge may not be necessarily so.
I'll have to see if I can find anything about those suspicious heaters.
Randy
Old 01-20-2008, 02:59 PM   #18
2000 34' Limited S/O
Jamestown , North Carolina
How long dry camping on 2 batteries
I realize that it depends on how much usage, but my wife and I want to do some dry camping this spring. Could I expect the batteries to last 4 days with just basic lights at night, water pump and flushing the commode, radio etc?
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 01-20-2008, 03:04 PM   #19
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
We have only one battery in our trailer and can get four days out of it if we do not use the furnace.
Richard
Old 10-18-2008, 06:07 PM   #20
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
good thread... just installed the 2020... used the 100A shunt... also ordered the 25' connector cable... not sure if I got the right black wires connected to G1 and G2... no markings at either end (whole length sleeved), and i didn't have my tone generator... but here's what i'm getting:
kill switch 'off' .05
kill switch 'on' everything off .05 (so far so good)
backlight on thermostat .14
systems monitor 'on' .12 (jumped to .15 when checking status for LP only)
front sofa fluorescent .67
front sofa direction spot (high) .47
sony stereo receiver .52
disc changer at rest .65
disc changer cycling .93
front fantastic fan (high/3) .92
water pump 1.60
(1)bedroom sconce 1.81
all fluorescent fixtures 4.57
all lights inc. fluorescent 11.70
boondockdad is offline   Reply With Quote
12 volt
No 12-Volt Power Silver Threads Batteries, Univolts, Converters & Inverters 28 07-03-2007 08:53 PM
Consumption Estimates campadk Electrical - Systems, Generators, Batteries & Solar 8 02-03-2007 09:54 AM
Poll: FUEL CONSUMPTION brunoffrance On The Road... 32 02-29-2004 04:37 PM
LP consumption by the furnace? ipso_facto Furnaces, Heaters, Fireplaces & Air Conditioning 18 12-10-2003 10:43 AM
Fuel Consumption: (curious) Drew Tow Vehicles 15 12-26-2002 06:28 PM
