Old 06-09-2007, 07:38 PM   #1
waynemorgan's Avatar
1976 23' Safari
geary , Oklahoma
power adapter-30 amp-2 15 amp
i have been looking for a adapter to convert 1 30 amp to 2 15 amp ,and cant find one anywere .
i gave the last two i had away years ago , they were about 8 inch long and 12 gage wire but i dont know who made them ,if i have to i can make one my self but thes were water tight and worked great...
AIR # 20946
waynemorgan is offline   Reply With Quote
Old 06-09-2007, 09:28 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Waynemorgan,
I just checked my Marinco catalog and my other suppliers. It seems that there is not an adapter as you specify being made now. You can get a 50-amp/50/50 'Y', or a 50-amp/30/30 'Y' as well, but nothing that goes 30- amp/15/15.
Remember that 50 amp park power is 240VAC with 2 hot legs and 30 amp is 120VAC with one hot leg.
It's not difficult to make one, but why not get a 30 amp/20 amp plug/socket and then use a 15amp/15amp 'Y' into that, or just use an outlet strip. Same results!
Old 06-10-2007, 10:12 AM   #3
1976 23' Safari
geary , Oklahoma
thanks, but will that not still give me 15 amps or am i not thinking right this morning ?
i need to put a 30 amp plug out side and have a waterproof box for a 30 amp only (2 of them)and have found that some campgrounds have 30 amp only .
AIR # 20946
Old 06-10-2007, 07:49 PM   #4
lewster's Avatar
The adapter I refer to is a 1 piece unit with hard matel connections inside. It actually provides the 30 amps into a 20 amp standard female socket on the other side of the 30 amp male plug. 2 - 15 amp 'Ys' will be providing 15 amps EACH to the capacity of the circuit....30 amps!
Old 06-11-2007, 09:02 AM   #5
1976 23' Safari
geary , Oklahoma
ok : now i get it ,thanks
AIR # 20946
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 08:10 PM
power boosters John Our Community 18 11-19-2002 04:54 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 01:59 PM
no power Mike Electrical - Systems, Generators, Batteries & Solar 10 08-20-2002 07:38 PM
Adapter / Electric from garage? bkpine Electrical - Systems, Generators, Batteries & Solar 8 08-13-2002 09:22 PM
