Old 08-08-2016, 03:59 PM   #1
Fancypantsas's Avatar
2016 23' International
San andreas , California
Portable Solar Panels
Does anyone have experience and recommendations for portable solar panels?
Fancypantsas is offline   Reply With Quote
Old 08-08-2016, 05:13 PM   #2
2015 30' Classic
Pleasanton , California
Take a look at Zamp Solar. They have a complete range of products. Airstream even added their Solar Port connector in 2017 models to make the connection simpler.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 08-08-2016, 05:50 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Airstream Life has just tested and stocked these portable solar panels in their on line store. The purpose of these panels is battery charging on sunny days. Don't think for a minute you can run your air conditioner with them.
Another recommendation for your consideration.
http://store.airstreamlife.com/searc...q=solar+panels
David
Old 08-08-2016, 06:49 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Personal opinion based on ownership and use. For the best quality and value check out Renogy.
http://www.renogy.com
MICHAEL
Old 08-08-2016, 07:49 PM   #5
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
I have the portable 200W ZAMP. The two panels are ok; they are as good as any and the controller is a good multistage. I purchased mine just as the controller was updated to something that is easier to read so I have the old that is difficult to see in bright sun, which is what you want when using the system to maximize the power collection. They allow me to have the trailer in the shade and the panels in the sun. When traveling I try to place the package where it will do the best weight balancing.
TheCabin is offline   Reply With Quote
Old 08-08-2016, 07:59 PM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I'm traveling for the dirt time with a Renogy 100 panel. I expect to try it in the next few days and will report back. We are very conservative with our power use when dry camping.
2019 Ford Expedition Platinum
Old 08-09-2016, 07:48 AM   #7
2013 25' Flying Cloud
Middleton , Idaho
I went through this last year, and eventually bought the 90W folding panel from Overlandsolar.com. The decision for me came down to storage size when traveling. The Overland panels fold into thirds and had a nice case for storage, which worked well in our situation. Our AS and truck mounted camper both have roof mounted solar panels, and have external Anderson connectors wired to the camper and AS mounted solar controller. The portable panel is an addition for when park in the shade, or need extra power, etc.
I liked the Overland set up because they wire it so you can easily bypass the panel mounted controller, and run directly from the panels to your trailer (if it has its own controller), to minimize voltage drop. But I would not purchase their 30' extension again, since it is made of 10 ga CCA (copper clad aluminum) speaker wire, not stranded copper. I made my own 30' extension with 8 ga marine duplex, and cut the 10ga CCA extension into shorter lengths for other projects.
Based on my research, there were many people that were happy with the Renogy 100w panel and it appears to be a good value. It was a very close second choice, and likely would have worked just as well as the Overland panels.
Trailbob is offline   Reply With Quote
Old 08-09-2016, 10:38 AM   #8
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I agree with Michael and am happy with my Renogy panels. They charge up the batteries well and are easy to set up and take down.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 08-09-2016, 10:43 AM   #9
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
Using the Zamp 120 for my 25ft. Portable, easy, folds up in its own carry case. Love it.
LilNomad
LiLNomad is offline   Reply With Quote
Supplement Factory Solar with Portable Solar dkottum Generators & Solar Power 10 06-16-2016 03:28 PM
Best Quality Solar Panels & Solar Controllers to use | Opinions Wanted BoldAdventure Generators & Solar Power 54 03-17-2016 06:04 AM
Solar panels vs portable generators ashe Electrical - Systems, Generators, Batteries & Solar 19 01-19-2015 07:18 AM
Adding panels on top of panels instead of replacing? The-Marco Ribs, Skins & Rivets 18 08-02-2014 04:53 PM
Portable Solar Panels migriffin Sprinter and B-van Forum 31 04-11-2014 06:56 AM
