Old 06-10-2016, 09:18 AM   #15
2009 27' FB International
Indianapolis , Indiana
Any update on the 15W Battery Minder Solar panels? Thinking about them.
amckibbe is offline   Reply With Quote
Old 06-10-2016, 09:26 AM   #16
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Phantom loads include CO sensor as well as the sub-woofer and the television (instant on feature). I installed a switch for the power to the sub-woofer and installed a new duplex outlet where one side was the switch for the outlet to kill power to the television. Also the thermostat and all the appliance control circuit boards could draw a small amount of power.
switz is online now   Reply With Quote
Old 06-10-2016, 11:07 AM   #17
2016 22' Sport
Clinton , Montana
Originally Posted by beachbouy View Post
I have attempted using a 7 Watts Solar Panel Battery Charger and it just is not enough to maintain the batteries while in storage evening with a top post battery master disconnect switch.
We generally store for a month before next trip and the 7 watt charger just is not enough to maintain both batteries.
I need suggestions for what would be a trouble free, sure thing, solar charger for the batteries as my arm gets tired cranking the jack when the batteries are dead.
Once on shore power the batteries charge BUT I beleive they have gone dead too many times and I should probably replace... they are Interstate Deep Cycle and the water level is fine.
Sometime shortly I will be adding solar and a good inverter but not sure who should do the work here in southern Florida... Our AS is prewired for solar.
Thoughts? Smartass comments are also welcome.
You've got a substantial investment in your trailer why not get a serious portable solar panel ....something like a RAMP Go Power 120 Watt Unit? About $650 and they do a wonderful job. My trailer is stored on our property about 1/4 mile from the house so there is no shore power available. The portable solar unit works very very well.
I understand that taking batteries to the "mat" several times will reduce their life cycle but yours are on a 2016 trailer like mine. They should be still good to go. Also,when stored are you "turning off the battery cutoff switch"?
Good luck with your issues.
Pat
Rpatrick16 is offline   Reply With Quote
Solar Panels Charging Batteries while in storage Chuck Barber Generators & Solar Power 10 07-21-2015 09:37 AM
Zamp Solar-80w portable charging kit-questions EmoryRiver Generators & Solar Power 5 05-14-2013 02:25 PM
Portable Solar Charging Kit AIR-Quarius Boondocking 3 12-29-2012 09:08 PM
