Old 05-07-2010, 12:49 AM   #1
1Bombshell's Avatar
Ventura , California
Plugged into 110, lights still drain the batteries.
We just had our 25 ft. Safari serviced. All checked out fine, including charger, 110v and 12v systems. Our trailer has been plugged into 110v for the past day, as we're getting ready for a weekend trip. My wife was loading up the groceries this evening and the lights were left on for 2 plus hours. When I went out to check on things, I noticed the lights looking a bit dim. The gauge on the wall reads 65%. Hmm... shouldn't this read 100% if it's connected to 110v? As stated, we just picked her up and all checked out ok. What am I missing here?
1Bombshell is offline   Reply With Quote
Old 05-07-2010, 05:01 AM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
Do you have a switch that looks like this?
Click here to see the battery switch
Fix
Dan@LED4RV is offline   Reply With Quote
Old 05-07-2010, 07:19 AM   #3
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
my disconnect looks like a regular light switch. it is on the curbside wall by the window behind the curtain on my excella 1000
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 05-07-2010, 07:55 AM   #4
2007 25' Safari FB SE
Blaine , Washington
Your battery disconnect switch is located to the right of your door as you enter. Make sure it is on, red light lit, when you are plugged in to outside power. That way your converter will run and keep your batteries charged.
John
Relentless is offline   Reply With Quote
6V upgrade - bad batteries or huge phantom drain? Phantom Batteries, Univolts, Converters & Inverters 12 05-05-2010 12:20 AM
House batteries drain ic2jack5648 Batteries, Univolts, Converters & Inverters 5 04-17-2009 02:03 PM
Reverse lights Stay on when AS is plugged in! shermantic Lights - Interior & Exterior 3 02-01-2009 10:15 PM
have 110 receptacles no overhead lights michaelsessa Lights - Interior & Exterior 4 04-29-2007 06:45 PM
lights 12v and 110 v moe146 Electrical - Systems, Generators, Batteries & Solar 5 05-16-2004 06:37 AM
