03-28-2017, 03:27 PM
Air Mobile
2005 25' International CCD
Newport News
, Virginia
Please recommend a good 6 volt battery
Hello All,
I bought my 25 Intl used about 6 years ago and it had the battery box retrofitted so it could hold 2 6 volt batteries wired in series. The system has worked fine but the batteries need to be replaced. I don't want to get into anything fancy but was hoping for a solid recommendation for a straight swap out of what I have. I'd like something that has a long life and good reputation. Thanks in advance, you guys are always a great help.
Tim
03-28-2017, 03:58 PM
Tampa
Good reputation seems to be Trojan batteries for golf carts, etc. I think they're in the $160 range, T-105.
I've used the Interstate Batteries clone which is about $110 locally. (I have two Interstate Battery stores near me.)
My current RV has 4 so changing them is expensive!
I'm a believer in only using distilled water and being sure they stay topped off.
Keep in mind you'll also have sales tax and a disposal tax. It all adds up.
03-28-2017, 04:37 PM
Walnut Creek
The Trojans are what my aftermarket guy recommends. I would investigate the Lifeline product to see if there is any advantage. I would also see what the Walmart or similar discount solution will cost you. With that info you should be able to make an informed decision. Will be surprised if the Trojans don't come out on top, but please keep us informed of what you find. Pat
03-28-2017, 04:44 PM
1988 Argosy 32
Lomita
I use Life line 6v 230 amps they are AGM so no water to check ect. they are not cheep
but well worth it.
03-28-2017, 06:32 PM
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Crown also makes a very good line. Choice of AGM or flooded.
03-28-2017, 07:43 PM
2004 28' Classic
Monument
2x Lifeline. They are great batteries.
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
03-28-2017, 09:25 PM
New Borockton
, Alabama
I wouldn't rule out Crown. They have my attention, that's for sure.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
03-29-2017, 08:32 AM
Curtis Wright
Eyren Haven
, South Jersey
Excellent batteries at lower costs than others. Labeled Duracell, made by East Penn, available at Sam's Club and Batteries Plus Bulbs.
03-29-2017, 11:02 AM
2015 25' Flying Cloud
GILBERT
I change my to Lifeline, order on line and get free shipping and NO tax.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
03-29-2017, 11:50 AM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
You need to evaluate your battery needs based on power density (amp hours vs. weight), size, and cost. Lewster recommends lifeline, but says even in some sizes the additional AH are not worth the increase in price.
guskmg
03-29-2017, 11:51 AM
GILBERT
I compare warranty, Lifeline is the best.
David & Nancy Ames
2015 FC 25' RB
03-29-2017, 11:52 AM
2007 25' International CCD FB
The Woodlands
I went with US made East Penn batteries, branded as Duracell. They were about $110 ea from Batteries Plus Bulbs for 230 amps. So far no issues!
03-29-2017, 02:08 PM
1967 26' Overlander
Spartanburg
, South Carolina
I don't know about 6v batteries, but I switched to a single Optima 12v battery about 6 years ago in my '67 and do not plan to ever buy a flooded lead acid battery again. The AGM's are more expensive but reguire no maintenance and for me outlast lead/acid 2 to 1 or better.
03-30-2017, 11:25 AM
Damien
2012 27' FB International
2023 30' Flying Cloud
Lafayette
I'm running two Lifeline GPL-6CT
04-03-2017, 06:31 AM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
I bought the same Duracell batteries from Sam's Club about 4 years ago and they have performed well; we mostly boondock. Cost was under $100 each.
Dan
04-06-2017, 08:27 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Some more accurate information for you. I bought my two Duracell golfcart batteries from Sam's Club 6 years ago. The 20 hr AH rating is 215 and the cost is $84.52 each.
Dan
04-06-2017, 08:40 PM
2008 27' International FB
Petaluma
Lifeline 220A 6V AGM GPL-4CT
I've been running Lifeline 220A 6V AGM GPL-4CT for 5 years with no issues. I have 400Watts of Solar keeping them charged.
04-07-2017, 03:52 AM
Air Mobile
Newport News
, Virginia
Thanks to all who posted. I ended up buying the Duracell Ultra High Capacity 6V Golf Cart Batteries, for about $100 apiece and installed them this past Monday. The item number at Batteries Plus Bulbs was SLIGC115. the price included 10% off for placing order online and picking up. Thanks again
05-19-2021, 05:10 PM
2019 27' International
2016 23' Flying Cloud
Nashville
, Tennessee
I’m looking to upgrade to 6 volt, how are the Duracell you purchased in 2017 holding up?
05-20-2021, 03:36 AM
Air Mobile
Newport News
, Virginia
So far so good, no problems.
