Old 04-13-2009, 01:05 PM   #1
Project1978's Avatar
1978 31' Sovereign
ABBEVILLE , South Carolina
Plastic Battery Boxes
I am new to the renovation of my "new-to-me" 1978 Sovereign International Land Yacht. I started by pulling out the front goucho, carpet, curtains, and the front lower cabinet. I noticed that there was some water damage on the sub-flooring close the front of the AS. I am not sure where the leaking water originated Behind the cabinet were the battery boxes flanking what seemed to be a plastic water tank with the top cut out of it. The tank housed the univolt and an outlet for the Air Conditioner power. The twin battery boxes are badly cracked where they disappear into the inner skin wall causing the boxes to slope back into the camper leaving a visible gap. I am planning on building/buying U-dinette seating for the front of the AS. My trouble is the two black housing boxes that hold the batteries. These boxes are badly busted on the top due to the weight of the batteries and no support btwn the box and the floor. Any info concerning the replacement of these boxes or repair would be greatly appreciated, even if it involves relocating the batteries and reworking the outside doors accessing the compartments.
Name:	Airstream Interior 001.jpg
Project1978 is offline   Reply With Quote
Old 04-13-2009, 01:24 PM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Battery boxes are available at most RV parts stores, most marine equipment stores, and I found the tall boxes for golf cart batteries at Wal-Mart, of all places.
Old 04-13-2009, 07:45 PM   #3
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
If you just want to replace the original battery boxes my first thought would be to see if you can get them from Airstream. If that doesn't work I used 2 of these boxes when I upgraded to a 3 battery setup.
Battery Boxes Vented for Sale
They're very easy to install and can hold up to a 29 series batteries. I'd think that you could just remove your old boxes and set these in the same location. Whatever you decide you need to get a box that can be vented to the outside from the top and bottom.
Charlie
Pacerized is offline   Reply With Quote
Old 04-13-2009, 07:51 PM   #4
1983 31' International
Belle Fourche , South Dakota
I bought one for my Sovereign last fall from Shorewood RV in Minnesota 1-800-784-2505. The part no. is 200855 and was $39.39
310astream is offline   Reply With Quote
Old 04-13-2009, 08:25 PM   #5
chrisd37's Avatar
1976 31' Sovereign
Marietta , 30064
It looks a lot like the batteries' present location is a relocation! That has got to be a homemade cut above them. My AS is a 1976 31' and its battery goes in a compartment next to the fold down stairs. It only holds one battery. Yours being a 78 might be ridiculously different but that totally looks like a homemade cut.
chrisd37 is offline   Reply With Quote
Old 04-13-2009, 08:51 PM   #6
1978 31' Sovereign
Thanks for the info... A little more info. From the outside, there are 2 locking doors that have gaps on either side of the lock mechanism. Not sure if this is standard or not. I don't have pics from the O/S yet. I think this is where my water trouble is coming from.
Old 04-16-2009, 09:09 AM   #7
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by Project1978 View Post
....Any info concerning the replacement of these boxes or repair would be greatly appreciated, even if it involves relocating the batteries and reworking the outside doors accessing the compartments.
I was faced with the same dilemma when I redid my '78 (http://www.airforums.com/forums/f219...ign-14737.html).
I built an aluminum gasket to waterproof the entrance door and sealed the edges with a rubber gasket. The vent above the univolt is for the transformer cooling - the "Buzz" from the old Univolt HAD to be stopped so I replaced it with a Xantrex unit - the newer solid state units do not require the cooling capacity of the older transformer types so I simply covered over the upper vent with a piece of aluminum weatherproofed with Vulkem.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 04-16-2009, 09:16 AM   #8
87MH's Avatar
1978 31' Sovereign
Images: 292
.. From the outside, there are 2 locking doors that have gaps on either side of the lock mechanism. Not sure if this is standard or not...
On the '78 Sovereign (Center bath, anyway) the curb side front is the standard place for the battery. The battery door sealed to the plastic box the battery sits in, so if the integrity of the plastic box is compromised the weather and water WILL leak into the trailer from the gap around the door.
The dual battery was an option on the Sovereign, but standard on the Excella model - I removed the battery to the front tongue, but kept the door to access the huge amount of storage area behind and below the gaucho. If converting to a front dinette, the importance of the front door lessens, and the door could easily be eliminated by covering the area with an aluminum patch.
Dennis
WBCCI # 1113
AirForums #1737
1978, battery boxes, international, sovereign, univolt
Water leak just above battery boxes, 1979 blickcd Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 02-19-2009 10:28 AM
Battery boxes and mounting msmst25 Batteries, Univolts, Converters & Inverters 4 06-15-2008 10:53 PM
Two Switch Boxes spat61 Land Yacht/Legacy Motorhomes 4 01-14-2008 07:35 AM
Battery and converter boxes? erock53 Batteries, Univolts, Converters & Inverters 2 05-05-2007 10:43 AM
Plastic battery boxes ! 77caravaner Electrical - Systems, Generators, Batteries & Solar 1 10-07-2002 12:57 PM
