Old 11-08-2012, 11:49 AM   #1
1976 26' Argosy 26
Columbia , South Carolina
Phantom wire in Argosy
I can not determine where this wire comes from or where it attaches. I assume that it is a ground wire and may attach to the frame as it is in the rear bumper compartment of my 1976 26' Argosy. I am in the process of changing out the univolt with a intelli power 9200 series convertor. help would be appreciated.
Michael W is offline   Reply With Quote
Old 11-08-2012, 12:26 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I think that wire might be the feed to the AC lamp on your monitor panel. With a new converter you wont have that feed out and will have to add a 12 volt power source to drove the light. Basically wire a 12 transformer which is plugged into the same 110 volt outlet as your converter. Simple project. If your light is an led keep on mind it will be polarity sensitive.
Old 11-08-2012, 01:01 PM   #3
1977 Argosy 24
Milltown , Wisconsin
If it is indeed a ground it probably goes to the frame of the old univolt.
ventport is offline   Reply With Quote
Old 11-08-2012, 04:04 PM   #4
1976 26' Argosy 26
Ventport I think you might be right. I did reinstall the univolt. It is still working with or without that wire grounded and it did not have any voltage while running the univolt. So I think I'll install the new converter and not worry about that wire. I do appreciate your quick response and close this thread.
Old 11-08-2012, 04:09 PM   #5
1976 26' Argosy 26
Thanks AtomicNo13 for the quick response, I think I'll just not worry about that wire and go ahead with the new converter install.
Old 12-04-2012, 09:55 PM   #6
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
OK, I just installed a new converter/charger, and I have the same wire. It comes right out of the Univolt and goes directly up to a fuse in the fuse panel.
I tried putting +12V on it, but no light on the control panel. I was gonna hook up a 120 Volt relay to it that would connect +12V to it when the shore power is on....
Looking at 24 ft. Argosy crunch27 Member Introductions 6 06-09-2013 07:46 PM
1972 Argosy Exterior Refinish billymyers56 All Argosy Trailers 47 02-04-2013 09:18 PM
1988 Running Light Exposed Wire vhariable Lights - Interior & Exterior 2 06-25-2011 08:56 PM
Where does this heavy black wire go? malconium Electrical - Systems, Generators, Batteries & Solar 3 05-31-2011 01:07 PM
Burnt wire on my univolt MonaxLisa Batteries, Univolts, Converters & Inverters 11 03-23-2011 12:31 PM
