Old 01-29-2015, 11:17 AM   #1
1975 31' Sovereign
Huntington Beach / On the Road , California
Phantom 4 amp inverter draw - Help please
I recently installed a 2000 watt inverter which draws 1 amp or less when turned on with nothing connected to it. When I plug the shore plug into the inverter (converter/charger unplugged and fridge on LP of course) There is a 4 amp 12 vDC draw from the inverter with everything I can think of unplugged or or disconnected on the AC side.
Is there anything else in the 110 vAC system that could be drawing 4 amps from the 12 vDC side of the inverter. Tank heaters, lights or something else I am missing???? The list of items I have disconnected from 110 vAC is below...
110 vAC Unplugged or Disconnected:
  • All outlets
  • Fridge
  • water heater
  • microwave
  • converter/charger
110 vAC still connected:
  • Air Conditioning Unit
Retodded is offline   Reply With Quote
Old 01-29-2015, 11:37 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
The air conditioner controls are a possible draw. I have seen it with my Armstrong air conditioner. There is likely a 110 to 24 volt transformer in there that is hot all the time
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-29-2015, 02:06 PM   #3
1974 Argosy 20
Kooskia , Idaho
Turn the AC circuit breaker off and see what that does. Report back. I can't think of any other load you have missed.
Turning the circuit breakers off one at a time should give you more to go on as to which one is causing the load.
low voltage cutoff vs AMP hours used at high amp draw morgandc Batteries, Univolts, Converters & Inverters 0 11-02-2014 10:38 PM
The Adventures of Phantom & Bunny - Travel Blog Phantom On The Road... 0 04-06-2010 11:14 AM
The Adventures of Phantom & Bunny - Florida Phantom On The Road... 4 12-13-2008 10:33 PM
Adventures of Phantom & Bunny - travel pics Phantom On The Road... 0 11-29-2008 11:17 AM
The Adventures Of Phantom & Bunny Phantom On The Road... 1 11-22-2008 08:07 PM
