Old 08-09-2011, 08:44 AM   #1
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
PD9260 or 9160 for '76 Argosy
Any suggestions? Will either one work on my 1976 Argosy? I currently have a functioning Univolt, but want to shed some weight and free up some space. Please help.
Phrunes is offline   Reply With Quote
Old 08-11-2011, 09:23 PM   #2
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Bueller?...Bueller?...
Any expert advice from the group on this one before I go out half-informed and fry all the wiring in my perty little trailer? Hahaha
Old 08-11-2011, 10:01 PM   #3
1974 Argosy 20
Kooskia , Idaho
Either one will do fine. The 9160 is older, but still a good unit as long as it has the charge wizard with it. Also, a 9145 or a 9245 will be fine. The last two num bers are the amp output/charge capacity. 45 amps is fine.
Old 08-12-2011, 02:55 AM   #4
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Is; more is better with dc amperage? I'm not at all familiar with dc current and the 60 amps seemed reasonable?
Old 08-13-2011, 09:36 AM   #5
1974 Argosy 20
Kooskia , Idaho
Only up to a point is more better. Your batteries will not take a much faster charge than the 45 amp models will give and I doubt that your 12 volt load is huge either. The original buzz box is 50 amps as I recall. You will not hurt anything with a larger unit, but it will cost you more money and probably not give you any better results.
Old 08-13-2011, 03:03 PM   #6
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Thanks Idroba,
I found a new (never used) 60amp with the charge wizard for $80. I don't think I can pass on it. Even though the old univolt is working great, eventually it will give up the ghost. I figgure since everything is out, I've put in new water lines, fittings, fixtures, fridge, sewer lines and valves, furnace, shurflow pump and AC unit...I may as well not skimp and get er done? Oh hell, I blew past the budget months ago, what's another $80 bucks? Hahaha
Looking for an owners manual for 1976 Argosy 24' btophek All Argosy Trailers 21 06-08-2014 10:46 AM
1993 30' (late 92 model) Excella :: 1993 Airstream Excella1000 arcamedies Airstream Registry Discussions 2 07-28-2012 09:10 AM
Argosy :: 1974 Argosy dlb56hdt Airstream Registry Discussions 0 08-19-2011 08:32 AM
Elsa :: 1972 Argosy Argosy 20 bobfowler Airstream Registry Discussions 0 08-19-2011 08:31 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
