05-10-2017, 09:22 PM
#101
New Borockton
, Alabama
Since Boog already has a funtioning Iota, I would use it too. If I were buying it today, I would use the Boondocker. Not a huge difference and similar charge profile but the Boondocker has a better warranty/value, comes in hard wire configuration and we never have problems with them. Boog will need to chop the plug off which voids the warranty but since its that old anyway, nothing to lose.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
05-11-2017, 03:52 PM
#102
Green Cove Springs
That's true and you are the expert. But for a novice to install, being able to just plug the PD 9270 into the outlet and not get involved in hardwiring made it easy, straightforward and relatively quick.
Breathe In, Breathe Out, Move On
05-11-2017, 06:30 PM
#103
New Borockton
, Alabama
I get it , don't blame you. You guys own Airstreams so you have to be resourceful
888-828-1893
Bestconverter.com
05-12-2017, 03:27 AM
#104
"Hey, I know you!"
Chapin
, South Carolina
Thanks again Mojoe and Randy, since I had everything apart for my PI surge protector install, I swapped out the converter for the Iota on your inspiration (cut the cord).
Sorry about stomping on the original PD4655 thread
05-29-2017, 01:08 PM
#105
2007 27' Classic FB
Shorewood
-Chu
06-17-2017, 05:15 PM
#106
2017 25' Flying Cloud
Lawn Guyland
, New York
Originally Posted by ATownTX
I installed mine yesterday on my 2016 FC 19' (same as the OP). There was one minor difference... The existing 110v AC black wire from the converter was not connected at the wire nut, it was spliced near the breaker with another wire that went to the wire nut. I had to remove the breaker to get to the splice. I cut the black wire from the parallax converter and put it back in the breaker (first removing the spliced wire) and then connected the 3 wires with the wire nut. The photo below shows the existing splice (pigtail??) that went to the breaker.
I ran into the same problem but didn't see your solution before I cut the black wire from the parallax at the breaker splice.
I guess now I have to run the PD 4655 black wire to the breaker splice, make up a new splice, and insert back into the breaker?
Also, does anyone have a suggestion as to how to back out the screw holding the white parallax wire to the distribution buss? The head on the screw holding mine is stripped and I cannot move it. I assume I can use one of the three unused positions for attaching the white from the PD 4655 but I am stuck on how to get the parallax wire out.
Walt
Walt
WBCCI - 29375
06-17-2017, 06:52 PM
#107
2015 25' FB International
my
, house
saving
06-18-2017, 01:39 PM
#108
Lawn Guyland
, New York
PD4655 Install with Pictures
Partial update - "it is a poor workman who blames his tools" - guilty. The stripped screw came right out after I went to Home Depot and bought a #2 square screwdriver type tool that apparently is exactly what i should have been using from the start.
Still stumped by the crimp connection that goes into the base of the breaker - I guess I will go to an electrical supply house tomorrow to see if they have something similar that i could use - unless someone can suggest a work-around - ATownTX can you describe your end result in a little more detail?
Walt
WBCCI - 29375
06-18-2017, 02:20 PM
#109
2016 19' Flying Cloud
Austin
I pm'd you. But basically I reused the crimp at the breaker and cut off one of the wires. Then spliced everything that should be on that breaker back together with a wire nut. It working.
06-18-2017, 05:11 PM
#110
Lawn Guyland
, New York
Clicks, sparks and smoke. I don't think I did it right . . .
06-18-2017, 05:18 PM
#111
Austin
I'm hoping you disconnected the batteries before you do this. If that's the case, and it's sparking after you hook the batteries back up, the. you will need to check ALL of your wiring.
06-18-2017, 05:37 PM
#112
Lawn Guyland
, New York
Everything was disconnected when I changed the converter. After I wired up the converter I connected the batteries and the D.C. Side was operational.
I connected shore power and flipped the main breaker and the next breaker. When I flipped the 3rd breaker (with the jumper) there was a series of clicking, then sparks and smoke. The breaker did not trip. I threw the main breaker and disconnected the shore power. The D.C. Side is still operational.
I have disconnected the battery, disconnected the shore power, and I have disconnected the wire nut and the three hot legs in the nut. I am having a beer and asking myself why I tried to do this myself.
Walt
WBCCI - 29375
06-18-2017, 07:51 PM
#113
2016 30' International
redondo beach
Can you take some pictures of where your at? Maybe we can help with your mis wire.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
06-18-2017, 09:18 PM
#114
Lawn Guyland
, New York
Yes, when i finish feeling sorry for myself I will shoot some pictures. May also try to reinstall the old parallax and let Colonial take a look at it when i bring Sparky in for some other warranty work in July.
Thanks for your help
Walt
WBCCI - 29375
06-19-2017, 11:43 AM
#115
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Walt
You can, any of the bus's screws can be used
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
06-19-2017, 04:46 PM
#116
Lawn Guyland
, New York
So after talking to the service department at Colonial and Randy at Bestconverter it appears that I hooked the black and white wires from the D.C. Side of the PD 4655 to the AC side of the trailer. I used the black and white wires on the left side of the converter, directly under the AC trailer connection. I should have used the black and white wires that were bundled with the green ground wire. Randy thought that the sparks and smoke was me burning out the board on the new converter.
Looks like the old Parallax will go back in until I can order a replacement PD 4655 - or I will leave if for Colonial to do in mid-July. A moderately expensive reminder to read ALL directions and labels a number of times and to check everything multiple times before throwing the switch.
Walt
WBCCI - 29375
06-19-2017, 07:19 PM
#117
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Yikes! You definitely let the smoke out.
Glad nothing worse happened, best of luck with the next attempt!
06-19-2017, 08:33 PM
#118
2011 20' Flying Cloud
SACRAMENTO
I had the same configuration as you and resolved it the same way.
I didn't order the remote but now that I see an installation, I can picture how I'd install it. However, my ZAMP solar controller also displays what the input voltage is to the batteries, so having the remote isn't quite so crucial.
09-12-2017, 07:49 AM
#119
2013 23' International
Penfield
, New York
Hello,
Thank you for your post. I have a similar situation on my 2013 23D. How do you remove the circuit breaker ?? or can I leave the black wire from the old converter in the unit with tape over the end?
Thanks for your help.
09-12-2017, 11:00 PM
#120
Palm Desert
I did the same damn thing. The instructions aren't very good IMO. This is a simple install and should take 10 minutes the second time you do it. But the first time is tricky. Sorry it didn't go well.
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
