Old 03-10-2017, 10:50 PM   #29
New Borockton , Alabama
Images: 21
Originally Posted by sinwing View Post
Snowy, thanks for the pictures and step-by-step instructions. Appreciate the extra time to document the installation and write it up for our benefit. Just ordered my PD4655 from Amazon.
Amazon? Check there is a serial number with it. Lot of unautherized dealers out there. If they are legit, they will help with install and supply you with the correct pendant.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 03-12-2017, 11:54 AM   #30
2017 27' Flying Cloud
Saratoga , California
Hi Randy,
Is sold by Amazon and look legit. BTW I didn't realize you are the Randy ( I didn't connect until I read your post) and you do sell the PD4655. I would have buy it from you if I know earlier - I do want to do business with members of this forum.
Journey'81 is offline   Reply With Quote
Old 03-12-2017, 01:57 PM   #31
Randy,
When I attempt to install, I found my 2017 27FB FC, dual ACs has the Parallax Series 5300, 55 amps, converter. See attached pictures of my converter/charger. The PD4655 will not work for me.
Visited your bestconverter.com. Look like I need the Boondocker BD1260HW, 4-stage converter/charger. The reason for the upgrade is prevent overcharging the batteries and to extend their life. Randy, would the BD1260HW works for me?
Also in your website, it stated "the BD1260HW is for hard wired application when a power cord is not needed". What does this statement means?
How difficult to remove the existing 5355 and installing the Boondocker? Does the BD1260HW comes with instruction for the removal of the 5355?
ID:	281295   Click image for larger version
Old 03-12-2017, 03:38 PM   #32
Images: 21
Sinwing,
You did get the incorrect part. There is no "kit" for the 5355 so the hard wire version of the Boondocker allows you to modify (remove and replace) the lower converter section and wire it to the AC side of the panel. The photos were taken from a member of this forums (Ms Tommie Fantine Lauer) and ARE the instructions. She made a nice lexan block to mount the fuse board to after installing the Boondocker but its not really necessary unless you just want to. Most people just mount the fuse board to the side of the converter.
I'm not allowed to link to the photos but you or somebody else can.
Old 03-16-2017, 07:39 PM   #33
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
Hey overlander, I asked a ? On your site. I'm ready to pull trigger but wan to make sure I'm getting the right stuff
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 03-17-2017, 04:37 PM   #34
Navarre , Florida
PD4655 Install with Pictures
Got my answer and ordered the pd4655 last night. I plan to keep current DC board and use the pendent routing through wall and into bathroom where I have my surge suppressor panel.
Old 03-18-2017, 10:25 PM   #35
Images: 21
You'll love it. The Pendant makes it easy to know what your converter is doing when connected to shore power and even when you're not.
Old 03-19-2017, 01:51 PM   #36
Navarre , Florida
Installed yesterday. Easy install. The cable of the pendent was too short to locate where I wanted so ended up splicing in an extension today. Guess everything is working ok. Light is blinking ever second or so.
Old 03-19-2017, 08:24 PM   #37
Images: 21
Blinking every second is the normal mode. Solid is boost and slow blink is float.
I've asked for a longer remote cable but the PDI engineer says might cause EMI issues so they wouldn't do it. I've had enough customers, and myself, successfully lengthen it that I'm going to hit him again with it. I think it's currently 4-5 feet and most put it on the outside of the panel door anyway so it's not a big deal but for those that want it further away, it would be nice.
Old 03-19-2017, 08:50 PM   #38
Navarre , Florida
Thx, one more ?. I notice that with shore power disconnected the pendent still blinks. I assume this is normal?
Old 03-20-2017, 04:14 PM   #39
Navarre , Florida
For those that have the 4655 installed, how long does it take to get to the slow blink state? Mine has been in for a few days now and all I see is the normal chg blink every 1-2 seconds. My AS is just sitting with shore power on and not being inhabited right now. I can cycle thru the states so that seems ok
Old 03-20-2017, 04:49 PM   #40
dasams's Avatar
Marin , California
I took delivery of a brand spanking new 2017 FC in Aug. We hit the road and have been staying in full hook-up parks the whole time. Guess what? We did some beach boondocking down in Baja and my May 2016 batteries are fried Had to buy a new pair at the Costco in Cabo san Lucas. Now back in the US and am placing my order for the PD 4655 with BestConverter.
Why oh why did AS install that POS Parallax unit? I'd gladly have paid them the $25 difference in the OEM cost
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 03-21-2017, 08:32 PM   #41
Navarre , Florida
Bump?
Old 03-21-2017, 08:40 PM   #42
Images: 21
Bump?
It's 48 hours of no voltage change (~.3 volts is the threshold) If you go in the Airstream and start flipping on lights or other DC stuff you keep resetting the timer.
Progressive Dynamics 4655 (PD4655) noise waldosgone Electrical - Systems, Generators, Batteries & Solar 47 10-31-2017 12:56 PM
Progressive Dynamics PD4655 Converter/Charger thinairflyer Airstream Classifieds 0 04-23-2016 06:42 PM
charge rate of PD4655 grizbear Batteries, Univolts, Converters & Inverters 11 05-04-2015 02:29 PM
PD4655 Converter Questions RubyDog Electrical - Systems, Generators, Batteries & Solar 7 02-27-2015 06:25 AM
PD4655 Converter No. 13 Batteries, Univolts, Converters & Inverters 80 10-18-2014 12:44 AM
