Old 02-26-2017, 09:26 AM   #15
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Originally Posted by dblee1950 View Post
Can I just replace my converter with this 4655 and my existing OEM batteries? Will this help keep them from over charging? My rig is only 8 months~ old so don't want to replace batteries until necessary.
Yes. If your batteries are in good condition, that is correct. Note that what also kills batteries is discharging them below 50%. That can easily occur when in storage if the batteries are not stored in a charged state or if the parasitic loads remain connected. A battery disconnect switch or disconnecting the cables is recommended. Pat
Old 02-26-2017, 09:34 AM   #16
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
Without removing bed top again, can I tell what converter I have installed on my rig? 2017 FC FB 25'
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 02-26-2017, 10:15 AM   #17
Navarre , Florida
Never mind. I got out to AS and saw info on panel. 8355. And 55A
Old 03-02-2017, 01:57 PM   #18
New Borockton , Alabama
Images: 21
Originally Posted by RivaHaven View Post
I have the 4655 and a 9200 series remote pendant... I could not see where the pendant rj45 plugs into the converter? Maybe I have the wrong pendant?
You can splice it like somebody mentioned if you already have the older 9200 series remote pendant but we now have a modified remote with the correct plug already on it.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 03-02-2017, 07:11 PM   #19
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
If you look at the last photo in the original post, you can see a cable that goes from the bottom left (with a brown end) up to the board with all the fuses on the right. Your pendant should plug in to the slot on the lower board (bottom left of that picture). You mention an RJ45 Jack - is that a phone jack? I don't recall that being the connector on mine - it's 4 pins but not a phone plug. Did you buy the unit from Best Converter? If so, give Randy a call and be sure you have the right part.
Good luck!
Old 03-02-2017, 07:39 PM   #20
Images: 21
The part number for the remote pendant that does not require splicing is PD92201TV
Old 03-03-2017, 05:03 PM   #21
2014 23' FB Flying Cloud
Park City , Utah
Necessity to upgrade if not on shore power long term?
If the longest I'm ever plugged in to shore power is a week or so, and then batteries are kept on a smart trickle charger between trips...is there any advantage to upgrading to a multi-stage converter? Or is it only when stored longer term on shore power with the stock unit that the batteries overcharge? It's a moot point because I just ordered one from BestConverter, but I am curious anyway.
pcskier is offline   Reply With Quote
Old 03-03-2017, 06:38 PM   #22
Images: 21
Lots of reasons including your example. No need for a trickle charger and much better charge profile when you are plugged = substantially longer battery life!
Old 03-06-2017, 05:52 PM   #23
Navarre , Florida
Originally Posted by Black7beard View Post
You have the option of achieving the same effect by using the optonal charge wizzard pendant that plugs right into the 4655 and can be mounted in any close by location. This give you the same blinking led light indicator plus the over ride button that is on the new fuse panel without having to switch fuse panels. On the included fuse panel the led and overide button are only accessible by opening the panel cover. The remote pendant can be mounted where is easily visible/accessible all the time.
In op photos the control cable runs from board below to the 12v board. If you use the pendant, I guess you splice cable from board below and nothing is connected to the 12v board?
Old 03-06-2017, 07:09 PM   #24
Navarre , Florida
There is no pd92201tv listed on PD website and the pd92201 on their site shows a phone type plug.
Old 03-06-2017, 08:18 PM   #25
Images: 21
It's not on their website but it does exist. I have hundreds of them, or at least dozens. They plug directly into the converter and not the phone cable plug but rather the 4 pin used on the 4600 series upgrades.
Old 03-06-2017, 08:24 PM   #26
Images: 21
Kinda, if you use the correct pendant, it does plug into the converter and no splicing is required. If fact, there is no reason to even change out the fuse board on the 7355 or 8355 since the same status indicator and over ride button is on the pendant and you can see it and use it without having to crawl on the floor and open the panel
Old 03-06-2017, 08:31 PM   #27
Navarre , Florida
That's kinda what I want to.
Old 03-09-2017, 03:58 PM   #28
2017 27' Flying Cloud
Saratoga , California
Snowy, thanks for the pictures and step-by-step instructions. Appreciate the extra time to document the installation and write it up for our benefit. Just ordered my PD4655 from Amazon.
Journey'81 is offline   Reply With Quote
Progressive Dynamics 4655 (PD4655) noise waldosgone Electrical - Systems, Generators, Batteries & Solar 47 10-31-2017 12:56 PM
Progressive Dynamics PD4655 Converter/Charger thinairflyer Airstream Classifieds 0 04-23-2016 06:42 PM
charge rate of PD4655 grizbear Batteries, Univolts, Converters & Inverters 11 05-04-2015 02:29 PM
PD4655 Converter Questions RubyDog Electrical - Systems, Generators, Batteries & Solar 7 02-27-2015 06:25 AM
PD4655 Converter No. 13 Batteries, Univolts, Converters & Inverters 80 10-18-2014 12:44 AM
