So I'm halfway through this. I've got the old converter out, took it out once I figured it was dead. Waiting on the replacement to arrive.
Pictures on the first post still aren't showing up for me. (Guessing it's a browser issue.)
PDF in the dropbox worked, tho'. Good to know I ended up on the right track, even before finding this.
I went w/ the lithium-compatible version: I don't have lithium yet, but intend to eventually: this will get me up and running now, and be prepared for lithium in the future.
PlayGuitar, yes, there is another white cable there, but it's the other one from Snowy's examples that comes from the converter below up to the board. If you're leaving the board and just swapping converters, just leave it; if you're swapping boards, you'd need to swap it over too.
-Leslie
WBCCI #1051
