10-07-2014, 06:41 PM
#41
2014 25' FB International
Little Rock
, Arkansas
FWIW: I upgraded to the Powermax boondocker the same week I picked up our new AS. There may be better ideas for mounting?? I didn't try to salvage the OEM converter case. I picked up some aluminum channels at HD to hold the converter off the floor for air circulation. Then I used some wood blocks to attach/hold the power center cover. With the cover on you can't see the wood blocks.
10-07-2014, 08:13 PM
#42
2022 Atlas
Homosassa
I have a PM4B Boondocker coming but it looks like it may be delayed cause y'all bought them all. LOL I look forward to seeing the installs. Mine is just a replacement for a Parallax 7455. Pray for no smoke and patience.
10-07-2014, 09:19 PM
#43
New Borockton
, Alabama
PD4655 Converter
I'd be interested to know about that Tater. Even if we run out from one warehouse we can ship them from another. Usually NO delay and I'm checking on that now. I can't see your order since I'm sure you didn't order it under the name Tater lol
I see Homosassa on your profile. I remember that. No reason it won't ship immediately.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
10-08-2014, 07:42 AM
#44
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
PD4655 Converter
Just got thru reading this post and was wondering if the PD4655 will be ok for a 71 Sovereign 31' with 30amp service plug (Furrion) that is totally stripped and going back with all new electrical, need all the help I can get. Need to get one ordered Thanks Jim
10-08-2014, 09:12 AM
#45
2022 Atlas
Homosassa
It has shipped. I have a tracking number.
10-08-2014, 10:00 AM
#46
New Borockton
, Alabama
Short answer is no because the 4655 is an upgrade kit for an existing Parallax 7355 and does not contain the AC breaker panel and DC fuse board. You would need a full power center or a distribution panel and a separate deck mount converter.
888-828-1893
Bestconverter.com
10-08-2014, 06:36 PM
#47
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
PD4655 Converter
Can you recommend one then if it doesn't go against Forum rules, I want to be sure when I buy one that it is what I need.
10-10-2014, 06:58 PM
#48
2014 30' FB FC Bunk
Hoover
, Alabama
Ok got it - looks like I'll keep my same fuse panel and replace only the converter
I'm off to look at it a bit later tonight
10-10-2014, 07:02 PM
#49
2014 30' FB FC Bunk
Hoover
, Alabama
10-11-2014, 01:45 PM
#50
2013 25' FB International
Beaverton
, Oregon
I just started replacing my 7355 with the PD 4655. While removing the old converter, I was removing the hot wire from the breaker. The wire was spliced with a short wire going to the wire nut. I was planning on just splicing my new converter wire with the short wire going to the wire nut and replacing the metal splicing gizmo in the picture below. My issue is, I cannot find where to get this metal gizmo. What are others doing who have come across this?
10-11-2014, 02:02 PM
#51
2014 30' FB FC Bunk
Hoover
, Alabama
Luckily my replacement came with the exact wiring with that doo dad and the twist cap - I suppose hardware store to get one
10-11-2014, 03:53 PM
#52
2022 Atlas
Homosassa
Randy, my Boondocker is open like Pharm's. The existing Parallax is enclosed in a metal case. Are you saying just put the Boondocker in and leave it open on top? Any chance of debris falling from the couch into the converter. I'm antsy about leaving it open since the original is enclosed. For some reason I can't post the image as it keeps asking for a URL of the image on the insert image button. Thanks.
10-11-2014, 04:03 PM
#53
2014 30' FB FC Bunk
Hoover
, Alabama
If Randy's reply does not rid said antsy feelings - then request the closed unit
For me actually I think it will be much easier to keep it clean of dust and dirt over time
I imagine the closed unit will still gather some dust inside - esp considering the fan blowing in?
With it open blowing it out will be easy and require no removal of anything - what does it take to remove the closed unit to use canned air - I plan on looking at my innards of my stock converter to see how much dust accumulated
Plus it may stay a tad cooler open?
10-11-2014, 04:23 PM
#54
2022 Atlas
Homosassa
Didn't know there was a closed unit option. That would be more in order to directly replace what is there. Will see what Randy says. Being under the couch and pulling it out to make a bed could be a problem if there's anything on the couch. Of course the rest of the box is open.
10-11-2014, 04:47 PM
#55
2010 28' Flying Cloud
Lower Alabama
, USA
Cut it and use a wire nut on the wire to power the converter.
I will post a photo when the board clears up. It has a gremlin at the moment and I cannot post a photo.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
10-11-2014, 05:13 PM
#56
New Borockton
, Alabama
You could build a cover if you're concerned about debris and exchanging for a deck mount is perfectly fine too. I can see advantages of each but I'll leave it up to you.
888-828-1893
Bestconverter.com
10-11-2014, 05:36 PM
#57
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Check my post here where I mention this very problem and how I resolved it with a short section of wire and a wire nut. http://www.airforums.com/forums/f449...ml#post1478980
10-11-2014, 06:00 PM
#58
2022 Atlas
Homosassa
Is the deck mount enclosed. What's the model number and I'll look it up. Thanks.
10-11-2014, 07:18 PM
#59
New Borockton
, Alabama
PD4655 Converter
Pm4b-60
888-828-1893
Bestconverter.com
10-11-2014, 10:37 PM
#60
Beaverton
, Oregon
I did just that! I looked at 4 different stores for that doo dad - nobody had it. I just cut the existing converter power wire and splice in the new one and tied it off with a wire nut. Once I did that, the rest of this install went fast. Currently showing 13.6v at the DC circuit board. 13.48v at the battery.
Thanks everybody for the advise, and a special thanks to Randy for being available and for the fast shipping!!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Converter fuse blowing (new converter)
wannaroam |
Batteries, Univolts, Converters & Inverters |
28 |
07-06-2015 02:39 PM |
Univolt 45 amp converter to a 30 amp converter
scooterbug76 |
15 |
02-24-2013 02:59 PM |
Converter relocation
FrankR |
0 |
07-31-2002 08:30 AM |
Converter box floor mount
FrankR |
Electrical - Systems, Generators, Batteries & Solar |
0 |
03-27-2002 10:34 PM |
Converter box for into floor mount
FrankR |
0 |
03-15-2002 09:49 PM |
